Last edit by: IB Advertising
What oil is the Best?
Any Quality 20/50 oil will do with a change every 3000 or so. Read more at:Oil
Read Full Discussion below
What Oil Is The BEST
#42
Mobil1
When I bought my new 09 Road King the guys at the dealership still subscribed to the "skate" theory against synthetic oil. (Bearings not rotating and going bad cause oil too slick) Was in St. Louis stop and go traffic on a hot day and that non-synthetic seemed too hot when I checked it. I read a two part article in American Iron that discussed skate theory as false.
Switched to Mobil 1 V-twin. My dealership accidentally put Dino back in and I could honestly tell. FYI found out it is also OK to go with synthetic during break-in if you want.
#43
#46
Any how, the dealer I go to told me not to use Syn 3 unless I wanted to amplify any mechanical noise from the engine. I like synthetics but if there is no extended oil change cycle why waste money? I've given up over-maintaining my vehicles. The precision in engine building today along with precise fuel delivery almost makes it a waste of time and money.
This doesn't apply to heavily modified engines.
Just my $.02 worth of fuel on the fire......
#47
Simple really, Any oil is better than No oil, other than that not much difference in modern syn motorcycle oils, but a lot of opinions/advertising . As you see here
#48
#49
I use 3 in 1 oil, it worked on my Grandma's sewing machine, it's good enough for me.
