2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Khrome Werks 2+2 Narrow Sweeper BarS Install
Old 06-18-2015, 10:24 PM
PeteF's Avatar
PeteF
PeteF is offline
I installed the 2+2 Narrows two nights ago. Plenty of electrical lines and brake line. Had to work a little for the hydraulic clutch line to get slack, but it all worked out. I don't understand the back orders. I ordered mine through the dealer and had them in two weeks.
  #72
Old 06-19-2015, 07:40 AM
Wolfman's Avatar
Wolfman
Wolfman is offline
How about some pictures?
  #73
Old 06-19-2015, 07:57 AM
MDSledhead's Avatar
MDSledhead
MDSledhead is offline
I probably wouldn't have needed the switch wire extensions either. Did anyone try to run these through the bars?
  #74
Old 06-19-2015, 01:29 PM
PeteF's Avatar
PeteF
PeteF is offline
I didn't run anything through the bars but the TBW of course because I didn't want to hassle with it. It appeared to me that there was enough stock electrical wiring to run internal.
  #75
Old 06-19-2015, 01:36 PM
FinalShot's Avatar
FinalShot
FinalShot is offline
I ran all mine internally. I had to open the hole at the dimple just a little so the connectors would fit through.
  #76
Old 06-19-2015, 04:46 PM
rideflhxs's Avatar
rideflhxs
rideflhxs is offline
6th Gear
Pete,
I have seen a lot of guys say they rerouted the clutch line but no real specifics on how. What did you do to get the slack? I have seen a pic on another post to cut the zip tie that holds clutch and brake line together at the steering head. Did you do anything besides that?
Thanks
  #77
Old 06-20-2015, 09:03 AM
MDSledhead's Avatar
MDSledhead
Originally Posted by rideflhxs
Pete,
Thanks
I cut the zip ties holding the brake & clutch to the steering head. As in the instructions at the beginning of this thread.
After everything was back together, I pulled as much slack as possible starting where the clutch line goes into the actuator(?) next to the right footboard. It snaps into a "keeper" up on the steering head (turn the bars to the left & look underneath the accessory panel). I also cut the zip tie there, repositioned the clutch line in the keeper, and reinstalled the zip tie (above the keeper). Up by the clutch reservoir, I loosened the banjo bolt just enough to line it up with the bars (same angle)
That got me enough slack that I could position the clutch line on the underneath of the bend in the bars where it goes into the faring. This is exactly how the stock bars were configured.
  #78
Old 06-20-2015, 02:09 PM
PeteF's Avatar
PeteF
PeteF is offline
That pretty much sums it up.
  #79
Old 06-21-2015, 06:18 AM
hapbob's Avatar
hapbob
hapbob is offline
Default Thanks I Hope
I'm on 3rd bar change on 2014 and I really hate the ones on there now. HD Mini Apes! They fit the higher and closer vs stock I was looking for but the wrist angle is a killer. You guys seem to like these and everything stock fits. I ordered through amazon and will be here this week. I gotta change the current and hope this is the last!
Hap
  #80
Old 06-21-2015, 09:06 AM
p51bombay's Avatar
p51bombay
p51bombay is offline
Hap
Its times like this when Helibars show their value
Quick Reply: Khrome Werks 2+2 Narrow Sweeper BarS Install
