2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Khrome Werks 2+2 Narrow Sweeper BarS Install
Old 07-16-2016, 08:15 PM
RFG7680's Avatar
RFG7680
RFG7680 is offline
Received 1,280 Likes on 733 Posts
We're your stock bars 1"? Just bought the +2 Sweepers for my road glide. My stock bars are 1.25"
  #182
Old 07-22-2016, 09:28 PM
hockey8787's Avatar
hockey8787
hockey8787 is offline
Originally Posted by Gators12
Great post from all, just what I was looking for sad thing they are on B.O. From Krome Werks. Won't see them until July 26th !!
Phat Performance has them in stock now, just got mine today,and installed!!
Also Dennis Kirk is showing 3 on hand!!
  #183
Old 09-13-2016, 03:49 PM
WoodButcher66's Avatar
WoodButcher66
WoodButcher66 is offline
I hate to assume things and I haven't seen this mentioned so I am going to ask.
Will these same bars (2+2 narrow sweepers) give the same results on my Street Glide? My assumption is they would being the Street Glide and the Ultra have the same fairing and all. But as I said above I hate to assume.
  #184
Old 09-13-2016, 04:49 PM
Udawg's Avatar
Udawg
Udawg is offline
Works exactly the same. I have them on my Street Glide.
WoodButcher66 (09-14-2016)
  #185
Old 09-16-2016, 11:06 AM
WoodButcher66
Udawg,
Do you like the bars on your street glide? Did you have to move your mirrors?
Kevin
  #186
Old 09-16-2016, 05:13 PM
Udawg's Avatar
Udawg
Udawg is offline
Udawg,
Kevin
I tired it with the mirrors for a little while but replaced them with the handlebar mounts and it's way better than the stock ones. I like the bars and they make a long ride much more comfortable. I recommend replacing the mirrors.
  #187
Old 01-22-2017, 08:12 PM
NCHD's Avatar
NCHD
NCHD is offline
Default Khrome Werks 2+2 Dealer Install Info
Hi All,
Just thought I'd let you know about my experience with these bars on my 2015 Ultra Limited given all the talk about cables, wires, etc. I had my local dealer install the bars and I asked for external wiring. They charged 3.5 hours labor and added switch wire extensions and the replacement throttle wire. The tech removed the fairing completely and measured everything. Clutch and brake cables remained stock and the clutch cable is neatly tucked into the fairing where it's supposed to be.
Hope that's helpful.
  #188
Old 02-02-2017, 02:00 PM
so60's Avatar
so60
so60 is offline
Default 2016 TGU TGS Sensor Cable
I just wanted to provide a little information about the TGS sensor cables on the 2016 model TGU. I do not know if this is applicable to all the 16 touring models or not. I just finished installing the Khrome Werks 2+2 Narrows on my 16 TGU. I read many many post and videos about changing bars on touring Harley bikes. I saw a lot of post about the "horrible" Green connector on the TGS cable. Like several others, my 16TGU TGP sensor does not have a green connector.
Th 2+2 narrows have the same little small holes for the switch wires and after much reading and looking at the bars, I decided I did not want to cut any wires, and the small connectors on the end of the switch cables did not want to come apart easily. So, not wanting to take a chance and mess one up, I used the extension kit 69200034. I decided to just run the switch wires outside, like they were from the factory anyway. The TGS wires were no trouble to feed through bar. I had enough slack on the clutch tube after cutting some zip ties here and there and the brake cable was ok also.
I am including some pictures of the two end connectors on the TGS wiring from my 2016 model. The 6 pin connector measures 7/16 wide and 5/8 long. The 2 wire connector measures 3/8 wide and 1 1/16 long. As far as I can tell the 16's are different, but I don't know if the 14 and 15 models are just like this one, or like the earlier models. I do not know for sure what the 2 wire connector is for, but it is not used on my bike...maybe heated grips or something? ***I found the PN for this TGS sensor for my bike from my 2016 Trike Parts Catalog, it is 32700050 and it appears that it has been used in some other model bikes from Harley.***
Attached Thumbnails Khrome Werks 2+2 Narrow Sweeper BarS Install-img_1867.jpg   Khrome Werks 2+2 Narrow Sweeper BarS Install-img_1868.jpg
  #189
Old 02-04-2017, 10:40 PM
kosanow1's Avatar
kosanow1
kosanow1 is offline
I just did the KW 300159 bar install. I ran all the wiring in the bar. Everything was going great until I went to put the right side heated grip on. The bars are a touch bigger and the throttle won't work smoothly. This is what the dealer said would happen. I'm going to try a couple thing tomorrow.
  #190
Old 02-05-2017, 09:09 PM
kosanow1's Avatar
kosanow1
kosanow1 is offline
The Bars had a high spot near the end. 2 minutes with a 4 inch grinder and the problem was solved.
Quick Reply: Khrome Werks 2+2 Narrow Sweeper BarS Install
