2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Tips to change clutch and brake levers?
Old 12-17-2014, 09:24 AM
kanddr's Avatar
kanddr
kanddr is offline
Default Tips to change clutch and brake levers?
Are there any tips or tricks to change the clutch and brake levers on a 14 SGS? The instructions weren't any help and the only thing I was told was to be careful of the microswitch. It looks easy enough but just want to make sure.
Old 12-17-2014, 09:44 AM
Harttoo's Avatar
Harttoo
Harttoo is offline
I have never damaged a switch,But service manual says to keep brake lever from hitting switch during lever removal.I have used cardboard,but I found that a wire tie,locking end is the perfect size.Clutch lever is easy after you slacken clutch cable.
Old 12-17-2014, 08:45 PM
Deaniverson15's Avatar
Deaniverson15
Deaniverson15 is offline
Just remove the snap ring from the pins that go through the lever and carefully remove and replace the levers. Easy enough!!
Old 12-17-2014, 10:03 PM
Bertk's Avatar
Bertk
Bertk is offline
The left Hydraulic clutch lever is easy. Remove the clip and pivot pin, slide the lever off, and the new one on.
There is a cup on the end of the brake lever that will not allow the lever to just slip off. I had to loosen the switch housing and remove the lever bracket along with clip and pivot pin to get the lever off.
Here's a pic showing the cup.
Old 12-18-2014, 04:13 PM
kanddr's Avatar
kanddr
kanddr is offline
Awesome. Thanks a bunch!
Old 12-18-2014, 06:08 PM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
How does one go about slacking the clutch cable on a hydraulic clutch?
vtHDrider
07-09-2017 05:48 PM
glcash
01-14-2017 05:51 AM
badasstruck
08-06-2015 02:49 AM
Brucewrs
06-05-2014 10:55 PM
SOCALHD
General Topics/Tech Tips
09-23-2007 07:08 PM
Quick Reply: Tips to change clutch and brake levers?
