Favor? ABS sensor
12-12-2014 | 10:12 PM
Favor? ABS sensor
Can someone take a close up pic of how the front and rear abs sensor is mounted?
I don't have my manual yet.
Thanks
12-13-2014 | 12:46 AM
I am assuming the little grey tab goes right up against the bearing. Confirm or deny?
12-13-2014 | 12:06 PM
Quote:
Originally Posted by
trainedkilla
The manual for front wheel installation says "be sure that groves on external spacer(s), or index pin on front WSS are on the outboard side. Rotate WSS until it makes contact with rear of fork slider. back off just enough to maintain clearance between WSS wire stem and fork slider" Hope that helps.
12-13-2014 | 12:24 PM
I appreciate it!
I just need to confirm placement of the rear sensor now.
in between the caliper bracket and the wheel.
The "feeler" touching the caliper bracker?
12-13-2014 | 12:48 PM
Yes that's how it looks. Index pin outboard then rotate WSS until pin makes contact with Caliper bracket.
12-13-2014 | 01:43 PM
Thanks alot! I will be throwing my wheels on this weekend.
SSTuner
04-10-2020 06:00 PM
SlimsSG
05-17-2019 11:35 AM
SpiderPig
Touring Parts
06-30-2012 01:32 PM
trucker7775
06-20-2011 11:22 AM
bikerbehaviorist
03-27-2009 11:11 PM
