2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
How do you install a Radio Shack Alarm
Old 07-07-2015, 07:47 PM
Womack's Avatar
Womack
Womack is offline
Originally Posted by AFRetired
Just did the Radio Shack siren on my 2015 Limited. Red to red, Black to middle (G/W). Works great, just like my 08 Ultra
I have a 2015 RGS. As soon as I red the thread I ran down to Radio Shack. I installed two RS sirens and man are they loud. Red to red, black to green, good to go. Best cheap mod every.
Womack
Old 07-07-2015, 08:39 PM
02BlueDeuce's Avatar
02BlueDeuce
02BlueDeuce is offline
Does anyone know if you can still use the HD Pagers if you use the RS siren? I want to do the Radio Shack siren set up but also want to get the HD Rechargeable Pager if they are compatible. I really want to get the pager so if its not compatible I'll just get the HD siren otherwise. Thanks for any info.
Old 07-16-2015, 07:46 PM
SquirtGun's Avatar
SquirtGun
SquirtGun is offline
Well I finally did the Radio Shack Siren upgrade to my 2014 Ultra. I used two sirens on the bike (part number 273-057). I used this part number because they are 108dB. I mounted one behind each side cover and It works great. The install of the sirens was the easy part. I ordered the Delphi connector from casper electronics and it took awhile to figure out how to install pins....Loud as hell!...Thank you all for the great information...you all rock!
Old 05-22-2017, 10:34 PM
JDJHNTR's Avatar
JDJHNTR
JDJHNTR is offline
I know this is an older thread but I was searching on how to install on a 16' Triglide and found this. I just installed the RS siren with the red to red and the black from the siren to the center white/green wire. The siren chirps when I turn the switch on and when I turn it off. On my 14' Ultra I had before it only chirped when turned off?
Anyone else notice this or experience this with the newer 16' model?
Thanks
Old 05-23-2017, 05:38 AM
1HD1C's Avatar
1HD1C
1HD1C is offline
my 16 chirps both on and off, think your 14 was supposed to also
Old 05-23-2017, 06:49 AM
josame's Avatar
josame
josame is offline
Has anyone been successfull in putting the Radio shack siren in chirpless mode on the newer bikes?
Old 05-23-2017, 07:36 AM
BigMike's Avatar
BigMike
BigMike is offline
Received 1,578 Likes on 679 Posts
Did you connect the siren to a batter to make sure the siren works?
The
Old 05-26-2017, 04:35 PM
ScreamingSkulls's Avatar
ScreamingSkulls
ScreamingSkulls is offline
My little how to for 2016 road glide special:
The following 2 users liked this post by ScreamingSkulls:
JDJHNTR (05-26-2017), RandyL (05-31-2017)
Old 05-26-2017, 06:20 PM
JDJHNTR's Avatar
JDJHNTR
JDJHNTR is offline
Thanks "ScreamingSkulls"! That's how I wired mine except I didn't cut the plug. The little wires on the siren had soldered ends on then and were stiff enough to push and lock right into the plug. I only used one siren but now you me thinking of adding another!
Thanks again brother!
Old 05-27-2017, 09:53 AM
Bobjv's Avatar
Bobjv
Bobjv is offline
Installed one on 2017 SGS, red to red, black to middle on plug, works great.
Quick Reply: How do you install a Radio Shack Alarm
