Who's done quick detach for TP ?
Who's installed TP quick detach kit and used the included license plate bracket ? I'm looking for side shots and straight on pics of how that bracket looks.
Basically I'm wondering if I can use that bracket WITH the oem TP rack (not quick detach). I know how odd that sounds, I have my own reasons.
I really don't need quick detach and all that comes the kit. On the RARE occasion when I'd pull the pack, I'd rather just pull the four bolts holding it on and take it off. If that license bracket does not conflict with the plate mount on the TP rack, I'd just have my plate mounted to it. I'd do Custom Dynamics for turn signals. But I don't know if the plate surface on the TP rack would interfere with the plate mount bracket that goes on the tail light.
I just looked at my install. The mount in the kit would need a lot of bending to work with the stock setup. With that being said, it looks like the stock license plate mount surface could be cut out of the mount and leave enough room for the mount that comes in the kit.
Edit: As you can see, the mount has to be laid down quite a bit. It would be the same if you cut out the mounting surface from the stock T/P mount, but I think it would be possible.
DJK
