I installed HD LED turn signals and tail light in July on my '14 RK. While checking her over before prepping for winter hibernation I noticed the left rear LED turn signal will not flash. Lights up fine in run mode, but nothing when it involves blinking for turn, emergency flashing or for security flash after turning off the bike. Also, noticed the left blinker light on the console flashes rapidly when pressing the left turn signal button. The rest of the lights work fine. Anyone experience a similar situation before I get into pulling things apart? Thanks in advance.
I would start by removing the tail light and try reseating the sig light connectors.If that doesn't cure the problem,try plugging the left light into the right light socket and vice versa. That will tell you if its in the wiring harness to the tail light,or the sig light wiring.
