Which O2 sensor eliminator do you use?
Hi,
It looks like my dealer is having problems finding an oxygen sensor eliminator that doesn't show any code (or switched on the yellow light) in the new '14-'15 touring bikes.
Which ones do you use with your Rushmore bikes? Did they show any error code or switches on the motor-yellow light?
Thanks,
Daniel.
Thanks,
Daniel.
I still didn't but I want because I use a decat header from a 2009 bike, sensors are located in the header head, very close to the motor so I'm getting error codes all the time (and I had to use an adapter because 2009 sensor holes were bigger than ours).
Using O2 eliminator will not only finish with these errors but also will allow me to work in open loop.
Thanks,
Daniel
Thanks,
Daniel
Strange, I have a decatted head pipe on a 14 RK without a tunner and a jackpot head, no cat on a 15 CVO limited with a tuner and I don't ever get any codes or CEL.
Are you running a tuner?
What other mods?
What are the specific error codes?
Are you sure that you got your O2 sensors back in the right pipe? This is a common error. The way that I remember it is the the black O2 connector is for the back O2 sensor.
What other mods?
Depending on how long your bike has been trying to deal with an altered exhaust and throwing codes, it's probably safe to say it's out of tune.
Might as well put a piece of tape over the check engine light or stop checking for codes and pretend that solved all your problems...
Which head pipe did you decatted? If it's a 2010-up sensors are located where the cat is but in 2009 the sensors are located close to the cylinders so the temperature is quite different.
Also the sensors were bigger 18mm instead of 12mm, so I used an adapter like this one: http://www.revzilla.com/motorcycle/b...harley-exhaust but it seems the sensor is not long enough to work (and the working temperature is quite big, as I wrote before).
When I'm in a constant speed, yellow error light disappears but, as soon as I accelerate it is again there.
Bike is running great but I just would like to get rid of this yellow light in front of my eyes.
Look into a Thundermax by Zippers, they have the big sensors and they are live feedback. I put one on my 14 RK and added about 20 horse power. It runs real strong now. This will solve all your problems. I know they are expensive but I found one on ebay for $400 and man it is worth it. Oh and it Auto Tunes. Sweet
Instead of putting on band-aids or trying to trick the system, why not just do it right and properly tune the bike for open loop?
![Icon Mrgreen](https://www.hdforums.com/forum/images/smilies/icon_mrgreen.gif)
Nobody uses 02 sensor eliminators in their 2014-2015 touring?
Tuning the bike for open loop is just what I did with my PV and, before using the "piece of tape" method (I must say I also thought about it in our last travel
) I would like to try with the O2 eliminator, just in case it appears any other error I will be warned by that light ;-)
With the sensors out of the main stream, they are not reading correctly.
