2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Speedometer and odometer accuracy, and warranty
Old 11-02-2014 | 07:02 PM
IdahoHacker's Avatar
IdahoHacker
My Super Glide will do 175 mph in 4th gear. I don't see a problem.
  #32
Old 11-03-2014 | 02:33 AM
nicliv's Avatar
nicliv
Mine is 5 mph off. Told the dealer to fix it got laughed at and was told it was in specs. If there is a fix out there why can't they just fix it?
  #33
Old 11-03-2014 | 04:13 AM
geektoad's Avatar
geektoad
So you guys that are sweating the accuracy of the speedo...Are you taking your measurements when your tires are brand new? When they're worn out? Somewhere in between? If you're that concerned about pinpoint accuracy of your speedo/odo, you need to take tire wear into account.
There is a over half an inch of diameter change over the life of a tire. That equates to 2-4% difference depending on the original diameter of the tire.
Actually, while I was typing this it occurred to me that belt stretch will effect the speedo/odo too. Minimally, but it's there.
Anyway...there's a reason why there are tolerance windows. Not ever thing is constant, and variables have to be accounted for.
My point isn't to slag anyone that has expressed concern out there, it's your bike and your time. I personally just can't get that concerned over the discrepancy.
  #34
Old 11-03-2014 | 05:11 AM
stuart1270's Avatar
stuart1270
Originally Posted by Greezey Rider
Why don't some of you clowns just go out and ride the damned thing instead of pissing around worrying about all of this stupid crap?
What do you care anyway? You'll probably sell or trade it with 1,500 miles on it.
Remember +7% or 105 miles the bike really has 1605 miles on it LOL
  #35
Old 11-03-2014 | 06:28 AM
biglew55's Avatar
biglew55
Actually, I do take into account the tire wear. I calculated it at some point and the difference between new and wear bars was a little over 2%. If you add that to the built in error, you're then 8% off. But if you start with an accurate reading with new tires, i can live with working my way down to 2% off, which is about 2 mph at 75. It's a valid point.
  #36
Old 11-03-2014 | 04:23 PM
tkm's Avatar
tkm
6th Gear
This has been annoying me for some time as well because I like to keep to ~5 over the speed limit because most people tend to to ~10 over around here. With ~10 over on my limited I'm still getting passed like I'm standing still. At what variance will the dealer fix it for being "broken" and not laugh at you for it being in variance?
  #37
Old 11-03-2014 | 07:04 PM
biglew55's Avatar
biglew55
I don't know if a dealer has the capability to change it through approved methods. I've never heard of anyone having it fixed with a solution from hd.
Tons of people have corrected it using a Power Vision or TTS, and gotten a great tuner that can help their bike run better at the same time.
  #38
Old 11-03-2014 | 07:21 PM
RushKing14's Avatar
RushKing14
According to a handheld GPS, my speedo is 3 MPH fast regardless of speed travelled. I have checked it at multiple speeds ranging from 35 to 70, and it's off by 3 at each one.
so based on my unscientific tests, the folks quoting percentages are figuring it incorrectly, as that percentage changes vastly with speed.
  #39
Old 11-03-2014 | 09:58 PM
JimScharf's Avatar
JimScharf
The speedo on my 2014 Limited reads 1 mph fast. Meaning I have to indicate 61 to be going an honest 60 mph. My 2009 Heritage reads 2 mph fast. Not enough for me to worry about.
  #40
Old 11-03-2014 | 10:15 PM
dvn4life's Avatar
dvn4life
Although I have not ridden every bike made, I've ridden several. On every bike I've ridden the speedo was off to some degree, and you never ever trust the fuel gauge.
Maybe that's just me.
Pat
Quick Reply: Speedometer and odometer accuracy, and warranty
