2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
wasn't the jiffy stand this time
Old 10-29-2014 | 09:39 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by Vernal
The rubber spacer keeps the shaft from moving.
So I can take both shifters off, and it won't move?
The rubber spacer is... well....
A spacer.
Old 10-30-2014 | 10:09 AM
jcapps's Avatar
jcapps
This is a joke ...........I hope
Old 10-30-2014 | 10:26 AM
offthewall's Avatar
offthewall
Originally Posted by jcapps
That shifter does not look like its in the right place. The shifter could never come off unless the bolt is out. It looks like you have the shifter positioned so the screw would chew through the splines
^^^THAT
The photo makes no sense to me. You shouldn't even be able to insert the bolt with the shifter in that position on the spline. The shifter normally cannot slide unless the bolt is completely out. The bolt rests in the indentation in the spline. Even if the bolt is loose, the shifter can't come off. The bolt has to completely come out.
Old 10-30-2014 | 11:09 AM
my67pnycar's Avatar
my67pnycar
Originally Posted by SecondGear
Really? I did not know that. I have to go read my warranty closer!
Everything from fender to fender (except normal wear/tear items) are the MOCO's problem for the first 2 years. I don't think a shifter falling off is normal wear and tear brother.
http://psndealer.com/dealersite/imag...servicefaq.htm
Paragraph 3.
Go see your dealer dude. If you are afraid to ride it, make them come get it.
Old 10-30-2014 | 03:00 PM
SecondGear's Avatar
SecondGear
That rubber piece is there. What is missing is the rear shift lever.
Old 10-30-2014 | 03:06 PM
SecondGear's Avatar
SecondGear
Originally Posted by offthewall
^^^THAT
The bolt that is on the stock levers is not big enough to keep the levers on. If you loosen you bolt just a bit, the levers can come off the spline. At least that was my case.
I bought one from Softbrake along with the proper spacer. The lever from Softbrake operates as you describe.
Here's a photo of my new setup.
Old 10-30-2014 | 04:08 PM
jcapps's Avatar
jcapps
Not on mine, nor any of the late touring bikes my friends own. I have made custom covers for a bunch of these after they removed the rear shifter
Old 10-30-2014 | 04:33 PM
SafetyMan's Avatar
SafetyMan
I've never seen one like that.... and I've worked on a BUNCH of them.
Usually, if you don't have the shifter in the proper spot, you can't even get the bolt through, let alone started.
Glad you're up and running!
Old 10-30-2014 | 04:35 PM
offthewall's Avatar
offthewall
Originally Posted by SafetyMan
I've never seen one like that.... and I've worked on a BUNCH of them. Usually, if you don't have the shifter in the proper spot, you can't even get the bolt through, let alone started. Glad you're up and running!
Same here. Something was messed up with that original shifter and bolt.
Old 10-30-2014 | 05:10 PM
HD-Gyro's Avatar
HD-Gyro
Default Lever falling off
I wish I could agree with you except it happened to me also in the first week I had it. The pinch bolt came loose and the rear lever fell off. Fortunately, it hung on the floorboard and wasn't lost along the road.
I tightened it with the allen wrench that came with the stock tool kit. By the time I got home, it was loose again and I could slide it on the shaft. With better tools I was able to crank it tight and it has been fine since then.
I agree, the pinch bolt will not go in unless the lever is aligned with the bare spot on the shaft, but it definitely slides on the shaft with the bolt in place on my scoot.
Quick Reply: wasn't the jiffy stand this time
