Radio issues
Radio issues
My 2014 Limited radio issues.
Upgraded the radio to 1.18.2 from 1.18.1 the day it was released. After installing the update the GPS zoom worked correctly and the USB would auto boot and play after boot-up. A couple days later the zoom returned to max zoom + or - the radio booted as default.
Today on the way into work the radio would cut out for a few seconds then return playing on multiple station. On the way home it started cutting again. I rode to the dealership about 17 miles away, radio cut out 30 times. The last time was 1/2 mile from the dealership. I shut off the bike but left the ignition on for the tech's to see it cutting out. You guessed it. It didn't cutout while the tech was looking at the bike, even after starting the bike. With the CB and intercom turned off they reloaded 1.18.1. They wanted me to ride it and let them know the results. The first stop sign from the dealer it cut out again. By the time I drove around the block it cut out 4 more time.
The tech looked at the bike again, it would not cut out for the tech again. Selecting Comm. The CB and weather option was missing. They asked that I leave the bike with them.
Will keep you posted on there findings.
Any chance you have guidance activated on the navigation system? Sounds similar to an issue I had right after the 18.1 upgrade. I was goofing around with the settings and must have activated the verbal guidance. So the music on the radio and my thumb drive cut out randomly, but only when the bike was moving. Turns out that the GPS and CB speaker output was set to the headset, but the radio set to the external speakers. The cutout was just the guidance system giving me directions, which I never heard since I was not wearning the headset. I deactivated that verbal guidance and the issue went away.
Another thing to check is the coax connector inside the tour pack at the left side (AM/FM) antenna. Mine was lose causing poor reception on FM and lots of popping and static on AM.
I've only had my bike 3 days BUT check the sat nav voice is switched off as it may be set to play thru a headset OR be on low or nil volume so the radio sounds like it's cutting out, happened to me today, switched sat nav voice off, sorted. �� u also said to happened at a junction, that's when it would be "talking "
The techs were never trained at all on the new infotainment system. The best they can do is get on the tech line with Harley. But they don't have a clue either. Pretty sad but they released this system at least 2 years too soon due to them just wanting to dump another new item onto the Rushmore bikes.
This sure sounds like the same issue I had when I accidentally turned on the CB option and my squelch was set a little low. This would explain the cutting out while moving but not happening when stopped at the dealers. Since you don't have a CB option showing something is definitely broken.
