I have the 2014 Ultra Classic, and have been looking to add the 'bike to bike' module. It doesn't look too hard, basically plug and play, then get it flashed at the dealer.
Well, mine (CVO Limited) comes with it, but the module on mine was faulty so I had to replace it. As you say, plug and play, then a 2 minute reflash at the dealer, and that's it. Does the Ultra still have the antenna and [obviously] the antenna cable from the tourpak to the fairing? If not, that will be a minor PITA to install, though not complicated.
Has anyone here done it? Is it hard?
Many of the accessories on the HD website have installation instructions you can download, might be worth a look if you're curious.
Its a little more than plug and play. Yes you add the module in the fairing. You have to buy the stud for the tour pak to mount the antenna. You also have to purchase the right side switch pod. Its a modular piece, the entire unit is changed in order to add the PTT switch.
jt
jt
You have to add another PTT? The bike already has the PTT on the left side for the stereo, it doesn't use that one? Thanks!!
