Stage 1 with stock mufflers
I might be interested in those, was just looking at them and Rush Big Louie's. What size baffles? PM me $? That is if the OP is not interested. Why the change from the Rineharts?
The benefits:
Intake = air flow into the engine for better engine operation and performance
Tune = Fuel / Air mixture for smoother engine operation and performance
Headers = Reduces the heat for the rider/engine, improves the sound increases performance by getting the hot air moving out.
Slipons = Continues moving the exhaust out more quickly by less restriction and gives you the sound your looking for.
I think you need all three to achieve what most are looking for, better conditions for the engine by reducing the heat and improving the performance and sound.
And if done properly, fuel air mixture, i think my economy, when driving conservatively has improved by 12%.
Go to the HD dealer on a weekend there will probably be every reasonable exhaust system and headers there on someones bike. I did that and questioned a few riders and they offered to crank the bike so i actually heard my setup on my model bike before buying it.
You might check into American Customs; they take stock mufflers and fit them with changeable baffles. Are still stock in appearance, but sound good.
Tests indicate the stock air filter on the 103HO flows all the air the motor can use; something to think about...
If you plan on future mods, a tuner that can accommodate those changes would be good. If no engine mods are in your future, something as simple as the Xieds may be all you need, or not..
You know - I am going to run counter to most opinions and say I think you have a reasonable plan if you like the looks and sound is not an issue. If you use an auto tuner it will adjust to the "actual" air flow and run very well. You won't have the loud, and maybe not as much final HP, but if that is ok with you go for it! As an example, I had a built 98" on an 02 ultra that I would put the stock muffs on when out west in Glacier and Yellowstone National park. I had a separate map for them, and it ran great - mileage even was better. It took two (not lightweights!) up and over the Beartooth with no issues at all.
I run the setup you are looking for and think its great but this subject will have a million different answers.
For me the sound is as loud as I would want it to be. Barks when you want it and quiet when you want it. I thru my 1 3/4 Rush mufflers on and it was way to loud and I truly think it was slower. Wouldn't mind trying out Fuel Moto's new E-3 mufflers but @ $600 I don't think so...
