Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri-Glide or trike a bike?
Old 04-08-2012, 08:00 AM
gm9's Avatar
gm9
gm9 is offline
Originally Posted by FLTR2008TRIKE
32k when first bought
Not bad. I don't know that you can get "out the door" for less on a Triglide.
Old 04-08-2012, 12:07 PM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
When I was doing some conversion shopping I was serioiusly interested in a DFT conversion. It was going to cost me 18 big ones.
Old 04-08-2012, 02:17 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
FLTR2008TRIKE is offline
That price was with the added tour pack, reverse gear installed. The bike was 18.5k the reverse gear was $1500 I installed the rake kit for 695 and then the rest was the trike kit.
There is additional money I since had to spend money to fix the poor weld on the shifter paw that failed. The engine that had a twisted crank because Harley uses a cheap designed crank. Built myself a strong 117" because of that.
Am I partial to my trike absolutely. I have one that stands out from others. I bought and built mine for the long haul. My last touring bike I had before my hit n run that took my leg I rode for 250k miles. That Electraglide is still running and being ridden today
Old 05-14-2014, 04:09 PM
RideCSC's Avatar
RideCSC
RideCSC is offline
Stage III
If you guys insist on being told "____ isn't covered under warranty", you can always buy a trike kit and purchase an aftermarket warranty like Pinnacle - 3 years for $300 or so. Not to mention with a good kit, you can pull a trailer without the warranty ***** coming for you.
Regardless, my dealer says that it's up to dealer discretion to honor a warranty and the high quality kits like CSC are typically honored under warranty.
IMO, bolting a solid axle to a transmission and praying that it holds up like the HD Triglide is similar to playing Russian Roulette... not to mention that it rides like a pickup truck compared to some of the aftermarket IRS kits. I visited a dealer in TN that had 4 busted Tri-glide transmission cases in his shop at the same time earlier this year.
As far as looks... The tri-glide looks like it got rear-ended. The short wheel base isn't ideal for handling, but it just looks plain goofy.
To each his own, but this is my idea of fantastic:
Old 05-15-2014, 01:44 AM
jlgale's Avatar
jlgale
jlgale is offline
I was going to use a Lehman kit for my '05 Road King. At the last second I pulled the plug on the order and traded it in for a '12 TG. Glad I did! Big part of why I did, was the frame was all one piece and the warranty. Always like to ride with my iPod and know I don't have to wear earplugs.
Old 05-15-2014, 06:13 AM
msocko3's Avatar
msocko3
msocko3 is offline
Actually the Triglide frame is 3 sections, front, intermediate and rear. It is however built to be a Trike, it has been strengthened more than its 2 wheel brothers.
Old 05-16-2014, 12:25 AM
RAP's Avatar
RAP
RAP is offline
Hmmm...I did not know my axle was bolted to my transmission Some of these pickup trucks ride pretty darn good The busted transmission cases must be a TN thing. Never heard of that around here and there is a ton of Tri Glides in this area. You have to be kidding about the handling, these things handle like a vette!!! But you are right about one thing, (To each his own)
Old 05-16-2014, 01:35 AM
Big ALbert's Avatar
Big ALbert
Big ALbert is offline
They do make a anniversary 2013 model a guy down the street from me has one
Old 05-16-2014, 06:51 AM
Noble Jim's Avatar
Noble Jim
Noble Jim is offline
RideCSC may have made an **** of himself. To each his own.
Old 05-16-2014, 09:45 AM
oldmsocko's Avatar
oldmsocko
It's quite obvious Jim he does not have a clue what he is talking about. People like that scare me.
Quick Reply: Tri-Glide or trike a bike?
