Performance Machine Virtue Contrast Cut Platinum Polished Wheels NEW
SOLD!!!!PRICE REDUCED $2200 The I have a set of new PM Virtue contrast cut Platinum polished wheels. The front is a 21"x3.5" and the rear is an 18"x5.5". They fit 09-15. They come set up for abs, however pm uses the same bearings for Abs or non abs. There are what they call "abs sensor plate"on the abs side of the wheels. Basically a small spacer on the outside of a non abs bearing that makes it abs width. So the abs sensor plate can be popped out of the bearing bore easily and used for non abs models. I was unaware of this setup until speaking with Rick Preuss at Pm. My bike is non abs so I got wheel spacers for both sides of the front wheel, if yours is abs you will only used one of my spacers and use your abs spacer on the abs side. Also included are pm front fender riser brackets and hardware for 14,15, and now 16 models. These are beautiful wheels I've just decided to avoid the expense of "blacking" out my bike like I had planned, chrome wheels will blend right in on my bike so I think that's the route I will go. Included are front and rear wheels, front wheel spacers, and front fender riser brackets for 14and15 models. No rotors or tires. Hog pro priced me out at $925 for both front rotors and tires mounted and balanced with dyna beads. Go to eastern performance website to see these wheels are easily over $2800 for the wheels and that doesn't include fender brackets or wheel spacers. $2200 shipped conus. Pm me.
