Notices
LED Accent Lights
Old 12-03-2013, 12:05 PM
FinalShot's Avatar
FinalShot
FinalShot is offline
Default LED Accent Lights
Where are you guys mounting them? Are you sticking them to the frame under the tank?
I'm also thinking I'll add them to the saddle bag lower support tube.
Old 12-03-2013, 12:09 PM
Webo's Avatar
Webo
Webo is offline
I mounted them under the tank on each side on the inside edge so that you would not see the actual bulb if bent over but just the glow. I also mounted a 12" strip on the inside of each frame rail on the bottom and on the saddle bag supports.
Old 12-03-2013, 12:19 PM
STLFLSTF_Mike's Avatar
STLFLSTF_Mike
STLFLSTF_Mike is offline
Do you have any night (lighted) pics of your scoot?
Old 12-03-2013, 01:44 PM
silverglide2010's Avatar
silverglide2010
silverglide2010 is offline
I put 2 under the tank, each side. 1 behind a/c, horn, under coil wires, crossbrase in front of oil filter. 1 under each saddle bag and 1 under front fender each side.
Turned out great!
Old 12-03-2013, 01:58 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,238 Likes on 1,002 Posts
Need to get some under front fender and I'll be good. And maybe a couple underneath on the frame rails.
Old 12-03-2013, 02:12 PM
Webo's Avatar
Webo
Webo is offline
Here are a couple in the garage. I tried to put one behind the horn and air cleaner but I could not get the air cleaner side to stick beacuse of the wrinkle black finish, so I decided not to do the horn so both sides would be the same. Im going to add the mid frame air deflectors and add a light on the back side of each one of them to light the back of the motor more. I used lights I bought at Autozone so I only have about $65 in it.
kabutl's Avatar
kabutl
kabutl is offline
Default Joe Florida LEds 207 kit.
I put some on both front calipers, under tank, under frame, behind engine, inside of swing arms, and under saddlebag frames.
Old 12-03-2013, 03:22 PM
ICIBUY's Avatar
ICIBUY
ICIBUY is offline
One 3 LED pod on the inside of each side of the front fender
2 - 16" strips under the tank mounted on the frame
one pod behind the air cleaner, and horn.
made my own brackets for pods on the rear so I could get the light to hit off the chrome wheel just right.
Made my own speaker rings out of the strips as well. Also did this for the 6X9's in the lids.
Old 12-03-2013, 04:49 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
Look at Boogey light web site at their instructional videos. They show locations and how tos.
I also put a strip under each footboards and a strip on the chrome bar under the tourpac
Old 12-04-2013, 07:33 AM
nchogfan's Avatar
nchogfan
nchogfan is offline
Try and get one under the bottom triple tree also. I loaded up my 2007 Ultra with them everywhere and I almost never saw anyone else with one under the triple tree to light the top of the front fender.
Quick Reply: LED Accent Lights
