Who Owns & Uses HF High Position Motorcycle Lift ?
Who Owns & Uses HF High Position Motorcycle Lift ? OPINIONS wanted from actual owners and users of this lift.
Now that i have lowered my RKC i have been thinking about getting a lower jack . HF High Position Motorcycle Lift is only 2.5" at its lowest acording to there web site and is on sale for $179
I can still use my handy HF yellow jack but its tricky getting it under with the road king lowerd .
So i am interested in some reviews from actual owners and users of this lift.
Thanks Austin
http://www.harborfreight.com/high-po...ift-99887.html
Now you can work on your bike safely and comfortably with this high position motorcycle lift. Supporting an 1100 lb. load capacity, the motorcycle lift provides a lifting height range from 2.6" to 30". The lift also features wheels for easy maneuvering and placement.
i
Thanks Austin
- 1100 lb. weight capacity
- Lifting range from 2.6" to 30"
i
Received 2,527 Likes
Look at the K&L Motorcycle Shop Dolly. Lift your bike with the yellow HF Lift you have now (Like mine) and put it on the fully adjustable dolly and remove the jack. Access it any way you like, spin and move it around with ease. I love mine.
Shop around on line, prices vary.
This is not the kind that has the "Kick Stand Tray" on the side, the bike will be high as you want, level, and rock solid.
I service on mine, move it around for cleaning the garage, it's the real deal!
Actually this piece of junk has worked out very well for my winter storage needs and it is rock solid.
Received 4,623 Likes
I got one last summer, needed two jacks, thought this would be good for a second, but now consider it the primary. Sure handy for a few things, getting that bike way up there, lets me sit on a roll around stool and work on the lowest points easily. It was a little wide to suit me for my sporties, but that was fairly easy to fix. If you don't have room for a table lift, this is the next best thing, although for some things you'd have to turn the bike around on the lift. Not being able to roll it around with a bike on it is a big negative; guys have put wheels on it and I'm considering that; it would increase the height, but it's got room for a couple or three more inches before that would be a problem with a Harley. I posted a thread with pics on the mod, and comments pro and con:
https://www.hdforums.com/forum/sport...-a-sporty.html
Here's another pic with a sporty on it.
