Can anybody tell me how much cranking amps a stock Harley Davidson battery on a 2005 road king would have ? I upgraded to a 95 inch big bore kit and still have the orginal battery and was thinking of replacing it with something more then the stock battery.
If you look around you will find stock sized batteries available with 350A or even more. It is quite likely the current factory battery is over 300A, as these things keep creeping up with improved battery technology.
When i did my 95 BB and head work i went to a bigger battery and starter. I found a yusa bettery that had 330cA and the 14.2 starter if i remember correctly.
Sorry really got excited, I wanted to say:
Just replaced the battery on my 05 95up King. Stock was 300CCA, my replacement was 400CCA and is an Eastern Penn manf. battery...
Try site http://www.etx30l.com/
When I did my 95 BB and head work I went to a bigger battery and starter. I found a Yusa battery that had 330cA and the 14.2 starter if I remember correctly.
I installed a 14.2 starter on a stock engine and I notice the difference.
That reminds me. I'm coming up on my 3rd riding season on the original battery. I have my battery load tested every year and always use a Battery Tender.
