Radio Shack - Alarm Siren Install - 2011 RGC
rusty289 (05-26-2016)
#182
#183
So we have three wires, one of which is a ground. Makes sense.
Do you know what the other two do? There is a wire being left out here, just trying to wrap my head around it.
Is there a charge circuit?
I was reading on another post, older bike where a guy hooked up a siren and it would chirp when the bike was moved but it wouldn't go into full alarm when the alarm was actually set off.
#184
My 3 wires are red, white with green stripe and black. The original directions were black siren wire to green and red siren wire to brown. What about the colors I described?
I have switched them around with no luck and even followed the directions to change the chirp/chirp less mode with no luck. I tested the siren on a 9 v
olt and it works.
I used the pins, are you pushing the pins into the back of the connecter on the bike?
olt and it works.
#185
#186
#187
For the Rushmore bikes, the R/O wire is for power, BK wire is for ground and the W/GN wire is for the siren.
#190
