Hidden Antenna
Received 49,992 Likes
1.This is the Harley Part number for the hidden antenna.
2. Has anyone tried this out yet?
3. Any ideas for covering the mast mounts on the Tour Pack?
I used a chrome 'acorn' nut available at a hardware store. I also used a chrome hex nut below the acorn nut because the acorn nut didn't have deep enough threads. You could also trim the exisiting stud a little if you didn't want the additional hex nut.
If you can't find the metric nut size (M6x1) you need, just get 1/4-28's and run a metric tap through them. M6x1 & 1/4-28 are very close. That's what I did.
Here's how I did mine. Cheap and it works great!
https://www.hdforums.com/forum/touri...-st-glide.html
You might consider keeping it all wired, and just go back to the tail whip on remote rides.
I picked up a powered antenna from a local car stereo shop. Looks the same as the HD one. Put it inside the fairing, plugged it in, grounded it and wired it to a switched power supply. I get as good or better reception than the stock whips even on the WB. Cost was $19.99, HD wanted $59.99 I think! Go figure.
