Plasma Rods
#71
#72
Plasma rods
Thanks Iceman24 and Vonzoog. I did not know that the plama rods are bright at any angle. I just got them from CD and will get the quarter round tomorrow. Friday I leave for the Laughlin River Run and I really wanted more brake lights. HD Forums helped a lot on my first day as a member.
#73
#75
Just watch the wiring harness b/c CD incorrectly wired the ground on mine (must've been built on Fri @ 4:59). Had everything wired correctly (to their cryptic instructions) and nothing worked. Started tracing only to find CD harness ground was in wrong pin on harness so one quick fix & "viola" it was like XMas on the back of my bike.
#76
#77
Plasma Rods
I have the same question. The plasma rods would be facing the saddlebags. Is it that the side of the LED strip is what you are seeing from behind? The first poster did a nice job, but it still seems that the rods are pointed 90 degrees from what you want. Sorry, but I am a newbie and just joined today. But I definitely want more brake light on my SG. Help would be greatly appreciated.
Good Luck
Overdoo
#78
As far as them facing the saddle bag its a non issue. The corner round moulding will provide a good gluing surface for the tape.When you purchase the 3/4" corner round molding just make sure you buy the pvc stuff not the wood. It will hold up in all kinds of weather and the double sided tape will really stick to it. Also make sure you clean everything good so the double sided tape sticks well on the back side of the rear fascia like I posted originally. This set up has been on my bike for a long time now with out any difficulty.
Good Luck
Overdoo
Good Luck
Overdoo
#79
