36mm Axle Nut Wrench
Old 03-08-2010 | 07:24 AM
BLACK BAGGER's Avatar
BLACK BAGGER
I use a 1 7/16 socket 110 ft lbs on the 06 king . They spec over 100lbs for tour bikes .
Old 03-08-2010 | 08:08 AM
badjustbad's Avatar
badjustbad
I have had the mufflers off and on my bike MANY times and I'm a bit worried about the potential for air leaks (not to mention the extra hassle of taking the mufflers off just to adjust the belt.) The HD wrench costs something like $85 at the stealer. They didn't even laugh when they gave me the price. I bought a cheap 36mm wrench and a cheap 1/2" drive socket - cut the end off the wrench and welded on the socket. I can now torque the axle nut to specs with just a bag removal.
BTW, if you don't torque the axle properly you may/will experience bearing failure on the IDS. I've had to replace mine at less than 20,000 miles and I suspect the stealer that was doing my tire changes (I do my own now) wasn't taking the time to torque the axle properly.
Old 03-08-2010 | 08:40 AM
BLACK BAGGER
I'm thinkin 110 ft lbs is a good #? I went 5lbs over acording to the fix my hog dvd LOL is this alright for torque 110 ft lbs anybody knom for sure?????/.
Old 03-08-2010 | 08:48 AM
dawg's Avatar
dawg
Mine states 95-105, loosen one full turn and re-torque.
Old 03-08-2010 | 09:00 AM
BLACK BAGGER
Thanks it's still on the table will do .thank ya for the info.
Old 03-08-2010 | 10:02 AM
ashmarc's Avatar
ashmarc
When I do replace my rear tire I will remove the exhaust, just seems to be the "right" way to do the job.
But I have to ask....the 36mm ratcheting wrench (pic attached) with an offset square opening for your torque wrench...........how is it used and can you really torque the 36mm nut properly?
I have always been from the school that says......a torque wrench is only accurate when used in a "straight/direct line" onto the nut or bolt. Extensions are OK, but no universal adapters or any "angle or offset" whatsoever....
So how does the wrench work where the attached torque wrench would clearly not be at a straight line to the fastener?
Maybe I'm not seeing it clearly?
Old 03-08-2010 | 10:13 AM
dawg's Avatar
dawg
At a 90 degree angle
Old 03-08-2010 | 10:25 AM
ashmarc's Avatar
ashmarc
So you're saying the head of the torque wrench does not have to be in a direct line to the fastener and can be offset?
See my very crude drawing...
Is this how it's used, and if so how could this apply proper torque?
Guess I'm still confused.
Old 03-08-2010 | 10:45 AM
dawg's Avatar
dawg
See the attached (slightly better than your drawing, LOL). Also read the attachment on my previous post.
rockhousebadboy (03-16-2017)
Old 03-08-2010 | 11:30 AM
ashmarc's Avatar
ashmarc
Dawg,
Awesome....I love me a good edumacation....I never knew that it was OK to use a torque wrench this way.
I may just have to get me one of those Kastar 36mm wrenches.
My V&H exhaust does not have separate mufflers. I would have to remove the entire exhaust to access the 36mm axle nut.
Thanks for taking your time to educate, maybe it helped others too.
Quick Reply: 36mm Axle Nut Wrench
