Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
  #51
Old 12-16-2007, 05:59 PM
Mississippi Bagger Mississippi Bagger is offline
Default RE: Wallow cured
Just went for my first ride after installing the ridestr8. Wow!
It's 36 degrees today and was raining and 21 degrees last nite, so was very careful keeping an eye out for patches of ice...only rode 35 miles and slower than normal. But what a difference, both straight and in the twists and turns!
Nothing "wrong" with the bike before, but so much nicer now!!! Hard to describe, but no mush or wallow.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
05 Road King Custom
Carburated
SE Stage 1 w/ K&N
Custom Fuel Moto Rush Slip-ons
HQ 0034 Cams
  #52
Old 02-08-2008, 04:01 PM
Ultra Rider 03 Ultra Rider 03 is offline
Hang Around
I know this post has been well responded now for a long time. But I am trying to understand whats really wrong with these bikes. Sure I understand the motor and trans move different from the frame and cause a rear steer. And yea I see how the ride-str8 and such can help. Butthe back of the trans has the swing are attachedand that in turn is mountedin rubber dounuts to the frame. Ok now I see up and down movement in this but if the swing are mount is shimmmed correctly between the frame mounts there should be no side movement and no need for the likes of a ride-str8. My 03 Ultra did move some till I shimmed it tight in the rear of the frame, is this all that is really wrong with these bikes? What am I missing here? Manuel
  #53
Old 02-08-2008, 04:11 PM
izzi izzi is offline
swing arm bushings are rubber mounted
  #54
Old 02-08-2008, 04:19 PM
Hang Around
Very true and it can move differently than the trans but these ride-str8 things are only connected to the trans, so if theswingarm moves what are these bolt on cures really doing for that? I'm just not following this yet [&o]
  #55
Old 02-08-2008, 04:29 PM
hogbag07 hogbag07 is offline
Ultra rider 03 Where did you fit the shims ? inside the fork cups.I looked in the parts book and theres no shims there
  #56
Old 02-08-2008, 04:33 PM
ken thompson's Avatar
ken thompson ken thompson is offline
The Schlong Man
Fixed my wobble by adding a few lbs to the tires. They were a bit low.
__________________
2005 RK Custom EFI 95" SE Stage II
Jack Horner: Don't just ram it in there like that, this is not a hole in the wall pal, it’s Rollergirl.
  #57
Old 02-08-2008, 04:36 PM
Hang Around
I made the shims from shim stock and they are between the frame mount and the metal part of the rubber mount.
  #58
Old 02-08-2008, 04:51 PM
Thats looks like the way to stop the wobble .Thanks for the help I will give that a try.Could you spec the shims so I can make before stripping rear fork cups.How did you workout what thickness of shims to use
  #59
Old 02-08-2008, 05:09 PM
Hang Around
I don't think you could make them up before hand. I had the rear wheel off and the shocks off also so I could feal any movement. I just added .010 shims till it would lock up the swing arm, then I removed a shim till it just freed up. Hope it works well for you as it did for mine anyway.
  #60
Old 02-08-2008, 05:22 PM
Hang Around
Oh I should also caution you thatyou need to brace the back of the engine when you pull the piviot blocks off as that is the mounting for the engine to the frame there. good luck!
Tags
baker, bike, dan, disguise, genius, harley, installation, instructions, kelly, persistence, ridestr8, semmere, touring, unlimited, wallow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
