Yep, I put a 160 E3 tire and 11" shocks which were not specific to this year bike and of course it bottomed out badly under load, took the shocks out asap but the damage was done. I now put a set of 12" shocks specific to this model/year and no bottoming out issues. Live & learn.
The harness includes the self adhesive conduit. If you look at my diagram, it has the pn# with an arrow pointing right to what you circled. Yes that is the 68772-06. This is what that harness consists of:
Awesome Dawg, just what I was looking for ...much appreciated!
Can't believe this is only $19.40 guess I'll run out and order one ...pronto!
Sounds like a straightforward rainy day install once I remove the rear tire.
That was what i did, i purchased the connectors and the pins and made 2 of them one for the bike and one for the wall.....just incase....it is easy and i made mine a little longer so i could tuck it in farther....
I have had this happen on a couple of different bikes. Just pulled the harness loose, cut out the bad spots, soldered in new wire where needed, wrapped in electrical tape, and then covered with flexible plastic conduit. Still working.
Co sign on this.... I just put on the tri bar chrome fender cap and ran the harness from the light assy. up to the opening for the wire harness to the tail light. Made sure the wire harness was clear of the tire. All looked good so off I ride. @0 minutes later The tail lights, and brake lights are out. I get home check the fuses. Both blown. I start checking for loose wires. I check the newly installed wire harness, it's worn thru. I cut out the bad wire. splice in new wire, Put wires in flex conduit. And reroute the whole thing. So far no problems. Cost for fix about $8. bucks.
got the harness in today from LSHD1, excellent service!
the harness comes assembled as one piece so it'll be "plug 'n play" and for $19.20 ..can't beat it!
Sorry I didnt get back to you on the harness plugging into the tail light, been kinda busy lately. I'm glad you found a solution. I guess taking the tire off is easier than taking the fender off. When I did mine, I just pulled the fender.
No biggie! You took the fender off?!?! No way am I going there, I'll deal with the tire, man ..then as usual my "homemade", taped-up remedy is working perfectly!! Lights, all not a problem so it'll be one of those rainy week-end projects.
