They should work together. I have an 08 SG and dad has 08 UC and he liked the light as well so he had put on and looks great. Only diff is mine color matched and his chrome. Hope that helps a little bit.
__________________
2008 Vivid Black Street Glide. Rineharts true dual exaust, passing lamps, back rests, and much more!
Does the '09 FLHX have the brake light at the bottom of the fairing like in the '10?
If so, will the rear fender of the '10 Street Glide work on an '09 UC?
I assume since the FLHX and the FLHTCU are from the same family, I also assume the rear fender from the FLHX will bolt right up...
See I like the tail light at the bottom of the fender, so I would like to swap them out if possible.
You want an 09 Street glide or Road Glide fender and the street glide fender extension +tri bar light. If you try to use a '10 fender it is not going to have the stock brake light mount/hole. Now you could use an '10 fender if you also buy the new '10 street glide turnsignal brake light bar...
Well I was just looking at the back of my bike again... I imagine if I remove the lower light and trim from my fender I could probably get away with just adding the fender extender and fillers right?...
Sorry if this is a repeat question...
__________________
2009 FLHTCU... The motor is funner!
Close. You'd need to do something about the three holes through the fender that the present light thing attaches with. The SG fender extender does not cover those.
Watch eBay,Craigslist or the classifieds, sooner or later someone will be selling a complete assembly. sometimes to do custom work, or maybe they are triking a bike or they are parting out a wreck.
I bought mine complete with lights, license plate mount and turn signals for $350ish.
__________________
06' Road Glide - SE 103", SE Six speed, SE Slip-Ons with Bub True Duals, HD Numbered Paint Set, Street Glide Rear Fender and lots of Shiny Stuff 99' Ultra - SE Intake,D & D Fatcat,Revolution 98",BC Gerlomy Bored Throttlebody,GMR heads, Andrews 37 Cams, Tour Pac Quick- Tach,Sundowner, Hog Tunes, SERT, Sirius 105 tq. 95 hp
As far as I've seen, the SG light in the rear fascia for the 09's and down do not act as a brake light. Same with the wiring. It's a simple 2 prong connection. The light does not have a dual filment so it will act no differently than the running light on fender now.
You might want to check with your local laws. Here in Canada we can not get the same tail light set up as the States. The tail light/ brake light, has to be so far off the ground. We get ripped off the cool back ends and have to settle with the "Witches Wart" tail light.
Hate to see go through all that for nothing. Your in Germany?? Long way to get parts. They may not let you take it off the base.
__________________
08 RG - Bub7 TD's, VIED's, V&H FP, Clearview +2, SG Fascia, SERG Bag Extensions, SERG Bezel. It's an addiction.
09 Street Bob - Bub7 Slip-on's, VIED's
I dont mean to seem like im chasing your post's and contradicting
The stock 09 tribar is running only. When you are adding the SG facia and trim you will buy the (09 and earlier model) tinted run/brake upgrade version. Plug and play. Total cost for entier mod is under $200.
__________________
Need to stop buying parts and ride the damn thing...
Heywood... Yup I am in Germany, USAF stationed here, so most rules don't apply... Our bikes and cars are inspected on base, so the only thing they truly care about is noise... 90db
Smokin... I was thinking about swapping out the whole rear light setup as well... plug and play sounds so much easier too
__________________
