Just popped my front wheel off to replace my lowers (07 Street Glide). Now I've got brake drag going on. Anyone have any insight into why and what I need to do to aleviate it?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
Your front wheel align needs tweeking. Did you use a 7/16" drill bit as a spacer per the manual? Don't know what mileage on your tire, but need for a balanceing will cause the brakes to rub.
...but need for a balanceing will cause the brakes to rub.
Please explain why a tire out of balance would cause the brakes to rub.
__________________
2007 White Gold Pearl Ultra Classic
Arlen Ness Big Sucker
Vance & Hines Dresser Duals, Ovals & FuelPak
R.J.S. Originals - Quit whining about the heat!
Soos Floorboard Extenders--They are Da Bomb!
FL, AZ & NV were rentals!
On my Road King the front wheel spacers are not the same. One is a little wider than the other. If not installed correctly could be a problem. Tires out of ballance will not cause the brakes to rub/drag. When you say your brakes drag are they binding on the rotor making it difficult for the wheel to turn? Or, do you just here a slight rubbing noise. The slight noise is normal, brakes binding on the rotor is not.
The pistons in the calipers are set for a specific alignment to the rotors. When reinstalling, its sometimes hard to get the axle/tire/rotors perfectly aligned back into the exact same place so one or more rotors may end up with excessive drag on a brake pad. Easy fix.
Take the calipers off
Push the pistons back some with a flat head screw driver or a C-Clamp.
Remount calipers.
Pull in the front brake a few times to set the brake pads in alignment with the rotors.
I like to take my calipers off and pump the brakes to let the pistons out and spray and scub them with a toothbrush with some brake cleaner...Make the piston go back in the calipers a lot faster and easier...releases pressure on the rotor.
