Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-03-2009, 09:48 PM
marcparnes's Avatar
marcparnes marcparnes is offline
Senior Rider
Default Removing '09 California Cat Equipped Header
In order to reduce the r/s heat a bit I decided to swap my '09 California cat equipped header with a '09 49 state header without the cat. I am also running vented lowers. There are a couple of things I ran into that as a novice would have been good to know in advance so I thought I would pass them on.
The exhaust flange gaskets supplied for my bike are quite long and a bear to install in the head. My dealer recommended a couple of much thinner ones that are easier to install and are supposed to work as well. I took him at his word and used the thinner ones which were very easily installed. The only problem was that they didn't work. At all! After reassembling the whole shootin' match I started it up only to have both flanges leaking like a sieve. I pulled the whole think apart again only to find that the ends of the header pipe hardly touched the gaskets at all. On my bike it seems that the pipe bottoms on the head before ever reaching the gaskets. Back to the dealer to get two new ones with the right part# this time. They are a definite bear to get into the port but with a good dose of WD40 and a whole lot of patience they went in. The system sealed fine this time.
The exhaust flange itself pushes against a split retaining ring which in turn pushes the header pipe into the port. Not having any idea what the rings originally looked like I reused them. Mine were beveled after having formed themselves around the header. Little did I know that they are flat to begin with In any case, one of them was so twisted that it ended up keeping one of the flanges from sealing. I brought them to the counterman and he took one look at them and gave me two new ones. Live and learn I guess. Anyway, if your rings aren't pretty flat its probably a good idea to just replace them. They only cost a couple of dollars.
The entire process of replacing the header is actually no big deal and can be done in about an hour or so.
The kicker was that the amount of heat reduction when moving is not noticeably improved without the cat. Its probably better when you're sitting in traffic but I didn't get to experience that. I'll see how it is when the weather heats up again. If you decide to pull your cat don't expect miracles
Marc
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 11-04-2009, 04:26 AM
wattspd's Avatar
wattspd wattspd is offline
Prospect
How much did that header cost if you bought it at the dealer?
Old 11-04-2009, 09:02 AM
marcparnes's Avatar
Senior Rider
Zanotti's $318.91.
Quote:
Old 11-04-2009, 09:06 AM
JCleary JCleary is offline
Prospect
Quote:
Originally Posted by marcparnes View Post
Zanotti's $318.91.
Or watch HD forums classifieds. I sold mine here for $125. They pop up from time to time.
If you have some nice slip-ons, like Rineharts, the sound of the exhaust is greatly improved. Bassier, louder, yeah!!!
__________________
2010 Vivid Black FLHX, SE Heavy Breather, Woods TW6-6, Mastertune, Thunderheader and a worn out right grip...
Old 11-04-2009, 02:46 PM
bamorris2 bamorris2 is offline
2009 Harley-Davidson Road King Classic
Marc
Wow, great info Marc! Really appreciate it. I have been considering doing this for my bike, but you may have changed my mind. I was under the impression that the non-cat headers would cool the bike considerable. Especially after reading what FuelMoto says about the 2010 cat models increasing headpipe temps by several hundred degrees.
Thanks again.
__________________
2009 Road King Classic
Vivid Black
Old 11-04-2009, 03:35 PM
Johan96's Avatar
Johan96 Johan96 is offline
Thx! Putting on notification
__________________
Vivid Black Flhx 2009 Phyton Predators, sest, ac, lower fairings, solo seat and bling
Vivid Black Fxdl 2000 Sold
Vivid Black Flstc 1996 Sold
marcparnes's Avatar
Senior Rider
Quote:
Thanks again.
As I remember it Jamie quoted 150 F difference between the non-cat and cat equipped bikes. This is obviously measured while sitting still. The cat is back under the transmission. When you're moving the airflow carries the heat out the back. The heat I feel when moving is around my ankle and calf which is upstream from the cat so probably not effected by it much. When you're stuck in traffic I'm sure the cat contributes quite a bit to the discomfort since the heat has nowhere to go but up towards your body. I still think its worthwhile to get rid of the cat even if it only helps in traffic during the summer. The cost of a used one is not much and its easy to change out. The only bummer would be if the state starts smog checking bikes Of course you could always put the cat header back as compared to a lot of guys who drill the cat out and would have to buy a whole new cat equipped header if the need happen to arise.
Marc
Old 11-04-2009, 04:49 PM
UltraKla$$ic's Avatar
UltraKla$$ic UltraKla$$ic is offline
Yup, the Screaming Eagle exhaust gaskets SUCK!! Been there, done that. The reason those that like them do so is because of the decreased possiblility of them "squishing" and obstructing the exhaust port, however, when the OEM exhaust gasket is placed properly, it is still unlikely for this obstruction to take place PLUS you get a better seal.
Lesson learned.
__________________
http://www.hdforums.com/forum/image.php?type=sigpic&userid=22122&dateline=121958  7778
2007 UltraClassic\103"BB\.030 Cometic Head Gasket\SE 255's
Doherty PowerPACC w/vents\Supertrapp SE's\SERT\Bagger Brace
M1 15W-50 in crank\Redline MTL in Primary\Redline Shockproof in Tranny
My other toy!
Old 11-04-2009, 04:52 PM
marcparnes's Avatar
Senior Rider
What he said
Old 11-04-2009, 05:25 PM
Big Pig's Avatar
Big Pig Big Pig is offline
Marc
Yep, but those of us not in CA don't have to worry about that since there are no emissions control requirements on bikes in our states. At least not in mine, so I saved a few hundred by just drilling mine out and it runs great and cooler now.
__________________
2008 Vivid Black Road King Classic
2010 Vivid Black Street Glide
The Cost of Freedom is Not Free....Let Us Never Forget
Tags
09, 2009, ca, california, emissions, glide, harley, header, remove, sale, street
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
