Hey my 09 has sprung a leak and started marking her territory at work and at home.
There is oil all over the left pipe too.
I thought it was the primary gasket, but when you reach up behind the primary next to the belt there is loads of oil up there. There is no oil on the belt tho, so to me that says its primary oil because if it was coming from the tranny then it would be on the belt.
I can see oil in the primary when I pull the cover, and the tranny oil level is spot on.
Anyone seen this before and got any suggestions??
I am worried that the dealer will baulk at fixing it because of the small mods to the engine...
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
2009 King - "One King to Rule them All"
Flame Blue / Pewter Pearl. HDI spec - ABS and Security etc. ABS disabled (its rubbish).
S&S 124 hot set up kit w S&S 640 gear driven cams / SE 58mm TB and injectors / SEST / Feuling pump and plate / V&H Power Duals / V&H Basic Slip Ons. 12.25 @108mph with screen n bags on.
Secret Weapon - Escort 9500ci
Brother that LOOKS... like it is right below your drain plug. Looks like a super simple fix to me. I'm no expert but you may just need to pull your plug - drain your fluids - replace the drain plug or seal it by any of a few different methods. and refill your Primary.
It could be the rear gear drive seal, they replaced mine under warranty. It leaked in the same spot. Feel the oil, is it thick (tranny) or thinner (primary). This seal can be replaced by pulling the primary. Agree with post above, check that primary drain plug first but, there should be a drop of oil on the plug if it is leaking.
__________________ Some things you just have to learn yourself....
Sorry, should have mentioned that I re torqued the drain plug and all the primary bolts a few days ago (none were particularly loose), wiped all the oil off and it is all back again. If it was just the drain plug there wouldnt be oil up on the back of the primary.
The oil is thick, I think it is gearbox oil, but it is hard to tell. there is no gearbox oil missing, the level has not dropped at all since the leak started.
How could the gearbox leak and oil get on the inside of the primary cover and not get on the belt??
__________________
First check the drain plug.
Second check the drive gear seal. If it is the rear gear drive seal make sure the dealer checks the bearings also.
If it is the drive gear seal wouldnt there be oil on the belt??
__________________
First have the dealer dye the primary. It saves them time and money. Trust me on this. There are a few more seals then the ones we all grip about. Mine had a aweful time and went back 5 times till they got it right. They had the factory rep look at it and he proclaimed that it was the primary case was porus. Any way I ended up with a new chome primary AND a new starter. Its an 08 ELC with 24 k on her at the time. Any way when I picked her up they tell me new case and new starter No leaks. Great but WHY the new starter ...it starts fine. The tech told me that when he took the starter off to change the primary inner that oil poured out of it. It seems that there is a seal behiend the gear and the oil then runs down between the tranny and gear case. Just and FYI to have them check it and dye the primary FIRST. Once they dye it they will have you run it for some miles then check it with a black light. No dye shining back then its the tranny. Good luck!!!!!!!!!!!!!
__________________
White, straight, Republican male (How else can I piss you off today!!)
NO, mine had no oil on the belt. Some things that can cause a rear drive gear seal to leak, over filling the tranny causing to much pressure or using too heavy of an oil. I was told they have had some leaks by others, not just mine. Just to refresh, the tranny oil is checked while on the jiffy stand and just put the stick in, not threaded in. What weight tranny oil are you running? Do you have a shop manual to look at?
When the seal went on my 03 softail(3times in 1.5 years and within 4K miles). There was never any oil on the belt. The only oil residue I found was on the back side and the shaft seemed to sling it everywhere but the belt. Then when it would sit gravity would do its job and it would puddle on the floor. The dealer tech finally replaced the bearings with the 3rd seal and problem was solved and the vibration I had since the bike was new was gone also. Of course I do realize that was a 5 speed and yours is a 6 speed but not that much difference in design.
