Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-04-2009, 08:09 PM
DD4life DD4life is offline
Hang Around
couple possibilities.
Behind the primary on the tranny is a vent tube (at least 01-06). Could be pressuring / foaming and leaking from there, or tube is damaged or missing, and leaking from the fitting.
also the main shaft seal on tranny could be leaking or the seal in the primary (two- one starter, one main shaft).
Guess you need to put bike on lift and look from underneath!
There are a couple others, but very doubtful, like a crack in a case.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 11-08-2009, 06:18 AM
kingkingking's Avatar
kingkingking kingkingking is online now
Thanks all for the suggestions.
Gear box oil is definitely dropping - down to the add mark now. So I am guessing main shaft seal.
Booked in at the stealer on thursday, warranty should cover it.
__________________
2009 King - "One King to Rule them All"
Flame Blue / Pewter Pearl. HDI spec - ABS and Security etc. ABS disabled (its rubbish).
S&S 124 hot set up kit w S&S 640 gear driven cams / SE 58mm TB and injectors / SEST / Feuling pump and plate / V&H Power Duals / V&H Basic Slip Ons. 12.25 @108mph with screen n bags on.
Secret Weapon - Escort 9500ci
Old 11-08-2009, 06:26 AM
fxlowboy's Avatar
fxlowboy fxlowboy is online now
Prospect
Look like mine this summer small drop of oil after each ride turn out to be the inner primary lipseal
__________________
07 flhtcu /103 cu.in /se 255 cam/Cometic 0.027 hg /SE quick install pushrod/HQ lifter/TTS Mastertune/HQ ProTuner
Old 11-08-2009, 09:36 AM
MI_Jim MI_Jim is offline
Hang Around
Quote:
Same thing happened to me last month. More of a slow seep than a leak because it only left a drop on the flor once, but it did tend to blow back on everything behind it. Waited for some cold weather and took it in for repair under the extended warranty. $50.00 later the leak is gone. Couldn't have fixed it myself for that!
__________________
Two of my favorite things!
'07 Ultra Classic
Jackpot Dyno Tuned Mufflers, S/E AC, PC V
Tags
124, 2007, cover, davidson, drain, harley, leak, leaking, leaks, left, oil, plug, primary, ss, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
