Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-31-2009, 09:17 AM
IsaacL IsaacL is offline
Hang Around
Default camshaft comparison
Looking at the specs of the SE204 it would seem that with a 4* adv key bringing the intake close back to 30* that it may be a good choice for the stock TC96" baggers?
Any thoughts?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-31-2009, 09:20 AM
UltraKla$$ic's Avatar
UltraKla$$ic UltraKla$$ic is offline
__________________
http://www.hdforums.com/forum/image.php?type=sigpic&userid=22122&dateline=121958  7778
2007 UltraClassic\103"BB\.030 Cometic Head Gasket\SE 255's
Doherty PowerPACC w/vents\Supertrapp SE's\SERT\Bagger Brace
M1 15W-50 in crank\Redline MTL in Primary\Redline Shockproof in Tranny
My other toy!
Old 10-31-2009, 09:33 AM
Dalton Dalton is offline
The 204 really is a cam that likes a little bump in compression to perform the best. If you want basically the same results on a bone stock engine, go with the 203, Andrews 21 or HQ500 and you wont even have to think about the advance key. Why try to make something work that wasn't designed for the application?
__________________
07 120" Hotrod Bagger
HeadQuarters Top End, Darkhorse Crank, Primo Pro Clutch,D&D Borzilla
TP Rocker Boxes, HPI 55mm TB, TTS , Baker DD7
Built by owner 125Hp/145Tq SAE Corrected
Renegade Wheels, Paint by Attitude Custom Painting
Old 10-31-2009, 09:37 AM
PhilM PhilM is online now
Quote:
Excellent advice!!!!
__________________
______________________________
Hint for today (and tomorrow!): ALWAYS use components that COMPLEMENT one another!
Old 10-31-2009, 09:50 AM
producer's Avatar
producer producer is offline
Prospect
Here's my thoghts,
If you pull the cam plate, put gear driven cams in with a 4 degree advance gear. You won't have any more cam chain adjuster maintanance ever again. On the other hand, will you really see a benifit to your low end torque with a 4 degree advance on a low lift cam? You will loose miles per gallon just to gain maybe 10 more ft lbs of torque.
I've been down this road and found something much better. If you are curious, I will write more. Any way, hope that helps.
__________________
2004 FLHTCUI-95"-HQ-0039G Cams-Dan Vance ported heads-CP FF Tops-10.4:1 CR-Stock TB-Fat Cat-SEAC-SERT-SE 6 Spd
Producer, Minneapolis, Minnesota
Old 10-31-2009, 02:32 PM
kmvallee kmvallee is offline
Prospect
2005 Harley-Davidson Road Glide
My Garage
Quote:
Originally Posted by producer View Post
Here's my thoghts,
Please write more I am interested in any information on this subject there is nothing better than experience and I am sure a whole slew of combinations have been experimented with.
Old 10-31-2009, 04:16 PM
truckerdave truckerdave is offline
senior experienced all-knowing leader of the unwise
I don't think they would be so good in a stock compression bike. There are better choices. Now I have SE 204's in a 103" engine with 10.1 compression and i couldn't be happier with it. I freely admit my cam choice was not based on extensive research and comparison but instead by the fact that i paid $100 for them new off ebay and i was pretty sure they would work just fine.
Old 10-31-2009, 06:31 PM
fastolds's Avatar
fastolds fastolds is offline
Prospect
A friend of mine works at the local shop and he did most of there dyno testing. He told me to get the 204's with true duals, air cleaner and tuner. He will be installing them for me soon.
__________________
Custom windshield trim
www.hobbymachine.net
Old 10-31-2009, 07:34 PM
Hang Around
Thanks for the advice folks. I will look for something else.
Old 10-31-2009, 07:36 PM
Hang Around
Dalton, thanks for the advice - I didn't realise it needed a bit more compression.
Tags
266e, 575, andrews, cams, camshafts, eagle, redshift, screamin, se251, se253, specs, tc, tw37b, tw60h, tw7hg7
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
