Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-30-2009, 07:49 AM
wildhog7 wildhog7 is offline
Hang Around
Default Popping Noise
I have a 2005 RoadKing Custom EFi that I installed a fullsac True Dual Kit and
replace the Air Cleaner with a Stage One Air Filter kit and now replaced the modify stock mufflers to a pair of screamin eagle slip-on Stage one mufflers the bike runs much faster but I am get a popping noise when it is in idle and in the morning when it is cold and i let it warm up a little and i hit the gas a liittle it hesitates a little. What could be the problem?
Frank
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-30-2009, 08:00 AM
imrotton2's Avatar
imrotton2 imrotton2 is offline
Senior Rider
you mite need to run some fuel treatment... injector cleaner..
__________________
it's not about what you are , it's about what you become !!!!
Old 10-30-2009, 08:31 AM
Hang Around
Thank you
Old 10-30-2009, 08:37 AM
rjmac53's Avatar
rjmac53 rjmac53 is offline
keep us posted...
__________________
Old 10-30-2009, 08:55 AM
Anthony8858 Anthony8858 is offline
Had the same issue when I added V&H true duals, powercommander, SE AC, and everything else
Assuming you may have a power commander....What you need to do is add more fuel in your 0% throttle position / 1000-1500 rpm range. I added a mere 5% more,and my hesitation / pop was gone instantly.
If you don't have a Power Commander, sorry can't help you.
What I discovered is when you accelerate from idle, you're not getting enough fuel, and you're basically choking.
__________________
2005 Road King Classic, with all the goodies.
Old 10-30-2009, 09:48 AM
FLHTCU Owner FLHTCU Owner is offline
What he said. If you don't have a PC, get one. If you do, then adjust it slightly. Should be zero decel pops with an EFI fuel management module.
__________________
Old 10-30-2009, 09:59 AM
onaride63's Avatar
onaride63 onaride63 is offline
Hang Around
Quote:
I have the harley race tuner and have pop on decel. The bike has been dyno'd twice and I still have it. Not as bad after the second dyno. The tech at the harley shop says that it's un-spent fuel getting into the exhaust. wouldn't this be a timing thing vs the way they have the tuner mapped ?
__________________
ride baby ride
Old 10-30-2009, 10:01 AM
jimsflh's Avatar
jimsflh jimsflh is offline
1987 Harley Davidson FLHTC
My Garage
Don't want to hijack this thread, but looks like the place to ask. My evo hesitates when I crank the throttle from idle, sometimes even almost stalls out. Also coughs and act like it's gonna stall when I down shift and then hit the gas to go around a corner. Quite by accident I found that pulling up the enrichener just slightly eliminates the lag/cough when I punch it from idle, so figuring I was running lean I opened the fuel mixture screw about 1/4 turn thinking that would help, but it didn't. Also alot of decell popping, which I kinda like. I was shooting flames out the back, but from experience, found a loose connedtion from battery which cleared up the missing that was causing unburned fuel to be pushed thru. This is after having the S&S carb apart and cleaned thouroghly and replacing everything on the accelerator pump side. When it's running at higher R's no problems, infact it pulled 84 HP and 92 ftlbs of torque on the dyno (after which I started hearing a squeek, or chirp from the primary if I pull in the clutch and let it out, or goose the throttle at low speed, need a heavier duty clutch?) Any suggestions?
(Man I must love this ol bitch, cuz if my wife gave me this much trouble I'd be single again!!!)
__________________
Ride Safe, Life is short enough!
Doc aka #1 Asshat
87 FLHTC Punched and streched to 89 CI, S&S Super E, White Bro's 2-1headers, Supertrap Muffler. - Just like me, old and ugly, but get's the job done!
Old 10-30-2009, 10:21 AM
Leftcoaster's Avatar
Leftcoaster Leftcoaster is offline
Quote:
Get a new tech - yours is incompetent.
__________________
Just smart enough to know how stupid I am.
Old 10-30-2009, 10:33 AM
onaride63's Avatar
Hang Around
Quote:
would love to but there the only ones around.
__________________
ride baby ride
Tags
accelerating, efi, harley, popping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
