Maybe I missed something here, but I think he wants to replace the starter ring gear, not change the primary gearing of the bike. I replaced my ring gear a few times after it got chewed up. Just use a hand grinder on the rivets, then knock them out. I used bolts, nuts, and loctite as mentioned about. It's been going on 10 years and nothing has worked loose yet. Alot easier than trying to rivet it again.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
Assuming your bike has the stock 34T/46T primary, your primary gearing is 1.353:1, so fitting a 49T will change that to 1.441:1.
If instead you can fit a 32T compensator sprocket, the gearing 32T/46T will be 1.438:1, which is as close the same as matters! (99.8%)So are there no 32T compensating sprockets available?
The last I checked a 32T was not available because a chain was not available without doing a half link. Thus, the 49T option.
There are three other things you can change to alter overall gearing, if that is what you want to achieve. It seems to me the clutch is the most difficult, the crank sprocket the easiest. What attracts you to doing this? Just curious.
I tried the 30t non compensated front primary gear this spring and it was a nasty sounding thing, I can't imagine that it was doing the crank any good, then I thought about the 30t rear drive gear and a new belt but from what I've heard it is a real pain in the butt to install, so that's why I'm going to do the 49T ring gear it lowers the ratio a good amount and isn't a total pain to install, and it only costs $300.
From the responces I've gotten here it doesn't sound like many people have tried this, but I have gotten enough info to have a pretty good idea as to how the ring gear comes off the clutch basket.
Sounds like a good plan. Let us know how it works.
It has been reported on this forum that EVO Industries raised the price for the 49T gear kit to $480ish....I know their website doesn't say this, but they told this to someone over the phone...
On Edit: Copied from EVO website: EV:1010-1221 Sprocket and Ring Gear Set 49 Tooth Fits 2007 and Later Touring Models Includes Custom Primary Chain.
List Price 482.54
__________________
2007 FLHX
103" Stage II,Andrews 31's,Headwork by Interstate Junction,Bassani PowerCurve TD's, B&E Superflows,SEST, Big Sucker II, 97 HP, 104 TQ...
Artfully Tuned by... Jason at Faribault HD!!!
I don't care what it cost's, it's on the list for this winter. Correction I just ordered it for $354.00 and that includes the boring tool and shipping.
It's not the starter ring gear, it's the primary chain gear that is on the clutch basket, that he is changing. The price on website is 480, you can get a whole new clutch basket with the 49 gear that weighs 2lbs less for 660 , both include new chains.
__________________
08 SG 103" SE MVA Heads 251 Cams SE 58mm TB RB LSR 2-1
