Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-28-2009, 04:58 AM
hot95hog hot95hog is offline
Hang Around
Quote:
Originally Posted by Roadking Cal View Post
You got the plug in far enough that the PRIMARY CHAIN was trying to saw it into bits.
I highly recommend checking/replacing the chain.
Just replace the plug as you banged up the threads a bit. It doesn't look like it hurt the magnet. As far as checking the chain. I would n't worry about it. You never ran it no where long enough to hurt anything. SOme teflon tape and run it in just shy of flush and your good to go.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-28-2009, 05:35 AM
Slayer dude's Avatar
Slayer dude Slayer dude is offline
Senior Rider
Thats not the drain plug that should never be removed on bottom of motor is it?
__________________
Night train/Standard sort of thing.
2006 Softail Standard
http://www.youtube.com/watch?v=BAVv8...eature=related
Old 10-28-2009, 06:02 AM
im im is offline
That is the correct plug for primary drainage.
It probably rubbed against basket or chain slightly.
Does not take much to grind it.
The hole for plug is straight thru the outer primary cover so it never bottoms.
Flush is good enough.
If needed there is a white teflon paste available next to loctite at autopart store..
I like the paste better because I think it offers less chance of a long strand coming off and blocking some passage inside or wrapping up against something.
Old 10-28-2009, 07:43 AM
usmcbay's Avatar
usmcbay usmcbay is offline
Prospect
Quote:
This is what I did... when I RE-drained and RE-filled the primary with NEW fluid it was to inspect the chain and what I could see of the Clutch bell... everything seemed fine. I didn't torque the bolt but ran it in until just at "snug" but the floss type tape I was using was just peeling off. That stuff is crap! I put the Teflon tape 2-3 threads above the beginning of the threads so shouldn't be any issues of lingering strips of Teflon tape anywhere. I thought maybe they had tapped it too far at the Factory but looks like others here say there is no bevel at the bottom of the tap to stop it - so... Lesson learned - won't happen again.
Thanks for the replies...
You can see my chain and Clutch in the Att'd photo (and my HD Pegboard... $50)
__________________
2003 Road King - 211Cam - Titanium P-rods - Hi-Comp Springs - AttitudeCustomPaint - 1.5" dropped rear - V&H FuelPak / StraightShooters - USMC emblems
Old 10-28-2009, 08:15 AM
Uncle Scrooge's Avatar
Uncle Scrooge Uncle Scrooge is offline
One thing for sure. . . the Moco made an improvement when they got away from this kind of primary drain plug to one with an o-ring.
__________________
06 ElectraGlide Classic
Old 10-28-2009, 08:57 AM
CroK's Avatar
CroK CroK is offline
1999 Harley Davidson Road King Police
Quote:
No, it isn't what you are thinking. It is definitely the drain plug for the primary chain casing. If you look at the bolts around the outer edge which hold the outer primary cover in place, it is the bottom one directly below and in line with the center of the clutch. It is not the plug next to the oil pan drain plug. Nor is the plug at the bottom of the right side engine casing under the cam housing.
Absolutely have to agree with that statement!
For those concerned about the teflon tape being wrapped too far over the end of the plug and coming off inside the casing... Even if it were to do that, it is not hard enough to do any damage. There are no small orifices for the pieces to plug. It would simply be chewed up if caught in the chain and sprockets. In the off chance it got in between the clutch plates, I'd think there would have to be a serious amount of it to do anything there like causing slippage.
Like I said in an earlier post in this thread, the magnet was completely sheared off of mine. And one half of the magnet was tossed off and stuck to the inner side of the outer primary case, just inside of the clutch inspection cover. The other pieces are most likely attached in a similar manner out of sight. When I pull the cover off next time, I'm sure I'll find them!
__________________
DARK RIDE
1999 FLHPI (Convertible)
SE 204 cams
Adj Push Rods
Baker DD6 Gear Set
PC3 USB
Old 10-28-2009, 08:59 AM
HarleyGoodies's Avatar
HarleyGoodies HarleyGoodies is online now
Premium Sponsor
Get a new drain plug at the dealer. It comes with the sealer on the thread already.
__________________
60 DAY MONEY-BACK GUARANTEE - FREE PRIORITY SAME DAY SHIPPING
EXTENDED PROMOTION - GET A FREE SKULL BANDANNA WITH EVERY ITEM ORDERED
Old 10-28-2009, 09:58 AM
t059736 t059736 is offline
Hang Around
Default Never use TEFLON tape
Owner's manual stipulates - NEVER use teflon tape
Other posts talk about this plug chafing.
Not clutch basket; probably chain.
Use only LIQUID thread sealer.
Old 10-28-2009, 10:24 AM
riteway's Avatar
riteway riteway is online now
Quote:
Originally Posted by Nightking View Post
That plug only needs to be tightened flush with the cover. Any more and it will go right inside. The newer models do have a shoulder on them. But, that is definitely a drain plug for the outer primary. I sure you were hitting something on the clutch basket. Do do that no more, ok.
"Do do that no more" NOW those are words to live by!!!
__________________
When i was growing up we had to put $1.00 in a jar whenever we swore.
What ever happened to all that CASH????I sure could use it now!!!!!!
Jake 3 years, Bodhi 3 months(Now 4 and 1)
Bernese Mountain Dogs
I am EXACTLY who my Dogs think I AM!!!
Old 10-28-2009, 11:09 AM
usmcbay's Avatar
Prospect
Quote:
I thought that was funny too... along with "Dude... I think you screwed up!"
Ha ha... I will keep it all in mind next time~!
__________________
Tags
big, black, davidson, drain, draining, gasket, harley, king, not, o7, oil, plug, primary, road, screws, sucker
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
