Was wiping the bike down yesterday and noticed the rear turn signal bar is a little loose. Just by looking at it, I'm assuming the bolts to tighten it are behind the fender and I will have to remove the rear wheel, correct?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
'04 H-D Road King Classic - Silver
No need to remove rear fender. I just used a wrench with the swivel socket on one end and had enough room to reach between fender and tire to re-tighten the bolt.
__________________
You all laugh at me 'cause I'm different......I laugh at you because you are all the same !!
2008 FLHX Vivid Black
2005 Ultra Intimidator 113" S & S
The rear turn signal bar on my 09 EGCb wasn't loose but it was mounted crooked.It was down on the left side,no problem getting a wrench up there without removing the wheel.Now all is well....lol
Thanks so much guys!! Actually layed down and looked up there and could see both bolts and YES I could reach in there (barely) and gave both of them maybe a 1/4 turn if that and it's nice and tight now.
This board comes through yet again
__________________
You may find that they loosen again. Best method is to remove one at a time and apply Loctite. You can get plenty of room by jacking up the rear of the bike and removing top or bottom shock bolts.
I have changed my rear signal bar and didn't need to remove anything to swap it out. Just had to get my hand up in there. Actually took longer to clean my hands afterward than it did to perform the swap. (the inside of that fender does get pretty dirty!)
__________________
HOG Life Member - Road Captain
2002 FLHPi HQ-0034 cams
Rinehart Tru-Duals w/ SEAC & PCiii
Bagger Brace - TOO MUCH CHROME TO LIST
