Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-26-2009, 11:23 AM
peddler peddler is online now
Default Ambient Temp Gauge/Chrome Bezel Removal
I'm in the process of ordering the Harley Oil Temp Gauge to replace the Ambient Temp Gauge. I've done research (search function) so I understand what this small project entails. Two small questions left unanswered.
1. I currently have the chrome bezel installed on the ambient temperature gauge. Can I remove the guage without removing the chrome bezel first?
2. Any suggestions on how to remove the chrome bezel either before I remove the gauge or after I remove the gauge from the fairing? Can it be reused? I have no objection to buying another set but don't want to if I don't have to.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
peddler
'07 Ultra-Vivid Black
SERT-SE Race Mufflers
SE A/C
IDS-Best investment
Wild One 575 Bars
Old 10-26-2009, 11:31 AM
wldbill's Avatar
wldbill wldbill is online now
Perhaps I don't understand your question, but the new gauge will have it's own bezel. It will all become very clear to you when you have
the gauge kit in hand and read the instructions. By the way, I mounted my sensor in the oil pan. Also, good info at this link.
http://hdforums.com/forum/touring-mo...-question.html
__________________
2009 FLTR
2008 Triumph Speed Triple
DON'T WORRY, BE HAPPY!
http://i173.photobucket.com/albums/w57/852299/320Blaster/DSCN8127.jpg
Old 11-01-2009, 08:57 AM
If you are using a spun aluminum gauge or silver gauge it comes with a chrome bezel built in. If you buy a black oil temp guage it does not come with a chrome bezel and the P&A catalog indicates it is not compatible with a chrome bezel. I believe the catalog is incorrect. The chrome bezel appears to fit the black gauge however until I successfully install it I'm not ready to suggest the catalog is wrong.
__________________
peddler
SE A/C
IDS-Best investment
Wild One 575 Bars
Old 11-01-2009, 09:10 AM
Araba Shriner's Avatar
Araba Shriner Araba Shriner is offline
If you have the stock guages for the Ultra like mine, (see picture)
the chrome bezel is actually plastic and just sticks on with double sided tape. So the bezel should pull off, hopefully you dont break it. But it would have to come off before you remove the gauge. Hope this helps
__________________
'05 - Ultra Classic
Florida Crew - S.W. Division
Ride Photos
Old 11-01-2009, 09:17 AM
Wally Wally is offline
I disagree, the gauge comes out the front (front of the inner fairing, not front of the bike), with the bezel on it.
Remove the outer fairing, unplug the wiring from the guage, remove the bracket that holds it in and push it through from the inside to the outside (towards the driver).
Remove the chrome bezel by first softening up the adhesive with a hair dryer or heat gun.
__________________
06' Road Glide - SE 103", SE Six speed, SE Slip-Ons with Bub True Duals, HD Numbered Paint Set, Street Glide Rear Fender and lots of Shiny Stuff
99' Ultra - SE Intake,D & D Fatcat,Revolution 98",BC Gerlomy Bored Throttlebody,GMR heads, Andrews 37 Cams, Tour Pac Quick- Tach,Sundowner, Hog Tunes, SERT, Sirius 105 tq. 95 hp
Old 11-01-2009, 09:42 AM
frenchbiker's Avatar
frenchbiker frenchbiker is offline
You're aware that this Harley oil temp gauge doesn't look like the others at night, right? Just to make sure you won't be disappointed after you install it.
The gauge has a white strip at the bottom of the inside lip, creating a halo when it's illuminated. I saw it on one of my friends' bike and it looks different.
I wonder why HD let this happen.
__________________
"Frenchbiker"
2009 Vivid Black Ultra Classic FF Edition w/ ABS
SE AC / PC-V / CFR slip-ons
"Sex is like bridge, if you have a lousy partner, you better have a good hand."
Old 11-01-2009, 03:41 PM
jberg jberg is online now
Senior Rider
Since the gauge comes out toward the rider the chrome bezel should just come out with it. The double sided tape that holds it on probably won't resist too much if you just pull it off. If it resists, just heat it a bit as stated above. Reinstall it by placing three small dots of silicone adhesive around the perimeter and push it into place.
__________________
ABS
Wheel-Dock Center Stand
Stage One, SERT, Monster Ovals
Bright-Ass tail light
Every piece of chrome available for under $150
Old 11-01-2009, 04:52 PM
Moe55's Avatar
Moe55 Moe55 is offline
Senior Rider
The guage will come out with the bezel on it. The Harley oil temp. guage is a little different where the bezel goes on. Parts book says that chrome bezel will not fit. It will with a couple drops of silicon. Don't notice any difference in the lighting on my guage.
__________________
2005 Ultra w/Bushtec Turbo 2
Old 11-01-2009, 04:58 PM
07JakeelwoodHD's Avatar
07JakeelwoodHD 07JakeelwoodHD is offline
Senior Rider
PS all the new oil temp guages now mount in the oil pan
__________________
09 HD Ultra Candy Rootbeer
FM PCV Rhineharts S/O S/E AC KN filter
07 HD Ultra Jake Elwood blue sold
Rinehart Slipons SERT S/E AC
02 HD FLHTCUI SE Exhaust SE AC race fueler
Old 11-01-2009, 07:54 PM
HarleyWood's Avatar
HarleyWood HarleyWood is offline
What he said...I reused mine from the air temp gauge ( I didn't need a heat gun though..a few drops of wd40 and the tape let go)
__________________
2008 Ultra Classic
Tags
2009, air, ambient, bezel, bezels, chrome, fltr, gauge, harley, kit, motorcycle, remove, sw, tachometers, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
