Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-23-2009, 10:44 PM
cdesero's Avatar
cdesero cdesero is offline
Hang Around
Default Glide-pro fl stabilizer users
Any one using a GLIDE-PRO FL stabilizer on there bagger? Do you like the way the bike handles?
Any problems with the install? Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
  • 2000 Ultra Classic
  • Stage 1 SE Pipes
Old 10-24-2009, 10:08 AM
cdesero's Avatar
Hang Around
Somebody must be using the Glide-pro or sta-bo stabilizer
__________________
  • Stage 1 SE Pipes
Old 10-24-2009, 04:21 PM
MMCNH's Avatar
MMCNH MMCNH is offline
Hang Around
I have the Sat-Bo II on my 06 Street Glide - I posted this after I put em on:
I chose the Sta-Bo 2 because I thought it would help with the wallowing I experience on curves (both slow and hold-on baby) on the New Hampshire roads . This isn't a debate of what stabilizer is better - or I haven’t felt any wobble, wallow or weeble. I am just saying for the 100 bucks (or so) I spent on it, it was well worth it. The bike rides tight and I can scrape my boards with a little more confidence. So if anyone is debating on getting these. They do work & work well. I also have not felt any extra vibration and they only took 20 minutes to put in. Ride On.
Old 10-24-2009, 08:58 PM
SA315B SA315B is offline
Senior Rider
I tried a different style stabilizer, gave it 20,000 miles and removed it. I was going to go with Glide pro but put an Élite 3 on the rear of my Street Glide and problem solved.
Old 10-24-2009, 10:43 PM
Mick's Avatar
Mick Mick is offline
I had a Glide-Pro setup in my 06 FLHT about 2 years ago.
The one I was using was the yellow bushing model , at the time.
Looks like he has changed the rubber compound a couple times since then.
The setup I was running (yellow bushing type) absolutely fixed the handling problems with that bike.
At that time , I picked up a slight bit more vibration and played with the forward mount to lessen the effect. The increase in vibration was acceptable when I was running solo , but my wife couldn't handle the extra vibes because of health problems (PAD).
I called Jake a couple times and we tried a few things to lessen the vibes.
He was very curteous and helpful.
After a couple months and about 1500 miles , I decided it wasn't working for me (us) so I returned it for a full refund.
Jake didn't question it and refunded quickly.
I was fully satisfied with my dealings with Jake and because of his honest return policy , would recommend him to anyone.
The kit did absolutely what it claims , and if my wife wasn't bothered so much , would have kept it in the bike for sure.
Just my findings.
Mick
__________________
2009 FLHTCU Flame Blue Pearl/Pewter Pearl
Stock (so far)
Old 10-25-2009, 04:42 PM
cdesero's Avatar
Hang Around
Just my findings.
Mick
Thanks for your time and info . How did the install go ?
__________________
  • Stage 1 SE Pipes
Old 10-25-2009, 06:10 PM
Mick's Avatar
The install is a bit more involved than some , in that I had to loosen my exhaust to gain enough room to remove the one bolt on the right side bushing block.
With 2 people , a bit of planning and a decent lift , it wasn't too bad , and we didn't have to de-tension the belt or anything.
Final torque of the bushings should be done while a rider is seated on the bike at ride height also.
I could change the amplitude of vibration throughout the bike by adjusting the front rubber mount (through bolt) with the engine idling and a rider on board.
If it wasn't for my wifes (bad) sensitivity to vibration , we'd have run it forever.
The biggest difference in feel for me was going over steel deck bridges , it was downright scary stock , and nothing at all with the Glide Pro setup.
Highway expansion strips were much better also.
Never got that "hula feel" with the stabilizer installed.
Mick
__________________
Stock (so far)
Old 10-25-2009, 07:40 PM
cdesero's Avatar
Hang Around
Mick
Great info and thanks again.
__________________
  • Stage 1 SE Pipes
Old 10-25-2009, 08:14 PM
Moe Taters Moe Taters is offline
Prospect
I had Glide-pro installed this past spring and the change is remarkable. Night and day.
Old 10-25-2009, 09:13 PM
Streetrunner's Avatar
Streetrunner Streetrunner is offline
I don't have the Swingarm bushings but I do have the Glide-Pro front motor mount which works great. Closest to the old HD 79B mount I have found. I might also add that is is a pleasure doing business with Jake. Real stand-up guy.
__________________
http://www.hdforums.com/forum/image.php?type=sigpic&userid=6202&dateline=1218219  897
'06 Street Glide
SE Slip-on, StageI A/C, SERT, Dyno Tuned, passing lamps and turned downed tips
Tags
camano, classic, front, glide, gliding, hand, harley, hd, island, motor, mount, pro, reviews, stabilizer, stage, ultra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
