Will the narrow band O2 sensors be close together near the collector? If yes, with no cat to buffer them, is it possible there can be an issue of "crosstalk". In other words the exhaust from the front and rear cylinders mixing somewhat before the individual O2 sensors are exposed to it?
The "crosstalk" you speak of in the stock headpipe is caused by reversion which is possible due to the way the stock inlet and outlet pipes merge in the collector. This is not an issue with our headpipe.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
I'm thinking of using your head pipes with Klock Werks SS Mufflers (https://www.kustombaggers.com/products/?id=239). I saw these up close and really like the look and finish. Thoughts?
These mufflers would fit our headpipes but we have not tested them
Jackpot Dyno Tuned 2/1/2 headpipes are the highest quality, best performing headpipe on the market. Designed specifically for the performance and tuning characteristics of the 96", 103" and 110" engines these 2/1/2 headpipes provide proven performance gains with a broad torque curve other pipes cannot match.
Our headpipes feature 304 Series Stainless Steel construction throughout with precisely machined billet Stainless Steel exhaust collars for maximum sealing and engagement into the exhaust port. Fully purged and painstakingly applied hand TIG welding is utilized through-out.
Dual Stainless Steel 18mm and 12mm Oxygen Sensor bungs accommodate stock O2 sensors as well as Wideband O2 sensors for closed loop tuning modules on all 2009 and 2010 bikes. This give users a wide range of options for EFI tuners.
Exclusive Jackpot "Tandem-Flow" large diameter merge collectors. This design allows maximum flow and convergence through the right side muffler path for maximum performance. Precise left exit spigot connects to OEM under-swingarm crossover pipe
Precisely vectored and formed CNC mandrel bent tubes assures full radius flow and exacting fitment
Heavy duty stainless steel mounting bracket is utilized for securing to the OEM mounting
Designed to work with Jackpot mufflers as well as other aftermarket and OEM mufflers , retains OEM exhaust shields
Jackpot headpipes do not have a catalyst and are not emissions compliant on OEM catalyst equipped vehicles.
2/1/2 Headpipes will allow 2010 Street Glide / Road Glide to be converted from a 2/1 single pipe to a dual exhaust*
* requires Jackpot heat shield extension which is $20.00 and additional OEM parts as listed below
Excellent performance increases with a Huge reduction of radiant and residual heat
Jamie...do you have any dyno data comparing your new SS 2/1/2 headpipe with a high quality 2/1 headpipe like the D&D FatCat or Pro-pipe? I realize that a true 2/1 will likely have stronger dyno #s, but if its close, your headpipe with OEM mufflers or higher performance mufflers might make for a "smarter" decision for the guy that wants a dual exhaust look and still wants measureable performance improvement.
How much do project your new 2/1/2 headpipe gives up to a true 2/1 headpipe?
__________________
2010 FLHTCUSE5 (SE Ultra) Scarlet Red Pearl/Dark Slate with Flames
Please call me for information. Out of respect for the other manufacturers and the products we distribute and represent we do not post direct comparisons. With that being said, the #s from our 2/1/2 headipipe and Dyno tuned mufflers were the best we have ever seen on a stock 96" motor with any exhaust we have ever tested.
