Any reason not to enable the rear cylinder cutoff?
I have an 09 Road King Classic and just turned 1,000 miles - had the initial service done. The rear cylinder cutoff feature came from the factory disabled and I figured I would leave it disabled through the break-in period. Winter is coming (if you can call it that in SoCal) so it probably wouldn't activate much right now, but thought I'd go ahead and enable it.
Any reason not to? I've heard about the smell when it kicks in - probably won't bother me. My main concern is engine longevity. I want whatever is best for the engine, and I'd think running cooler when sitting still would qualify. thanks.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
Ed - 2009 FLHRC
Wife - 2010 FXDC
I'm no MoCo technician, but having the EITMS enabled was definitely nice during Sturgis when I made my 1 trip down Lazelle street during the daytime with a bazillion cars/bikes/RV's.
That said, I wouldn't hesitate to enable personally.
__________________
KoalaCowboy
09 Ultra - 103" Stage III, MoFlow AirCleaner, BUB 7's, Pewter Pearl Inner, Brushed Aluminum Gauges, and much more!
Mine has kicked in many times,and it helps.I haven't noticed a smell though,only difference is it is obviously running on one cylinder.Sound and vibration.
__________________
2010 Ultra Classic,Red Hot Sulglow
It's interesting that the maps for the higher performance engines that come with the 2010 SuperTuner, have the EITMS turned off. If you look at the HO 113 and HO 110 maps with 58mmTB and larger injectors, they both have the EITMS turned off.
Anyone have a thought why engine maps for higher performance engines would have the temp manegement turned off? Could it be that since the maps are delivering far greater fuel (therefore running cooler), there's less of a need to turn one of the cylinders off?
__________________
2010 FLHTCUSE5 (SE Ultra) Scarlet Red Pearl/Dark Slate with Flames
I can see having it disabled during the break-in period, but the only reason I could see keeping it disabled, would be if you're in a cold weather climate area.
