Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-21-2009, 11:57 PM
blownrocket blownrocket is offline
Hang Around
Default *help* tbw ape bar question
hi guys have a question.
i just installed 12" apes on my 09 road glide. internally ran all the wires and buttoned everything up and everything works as it should,lights switches..etc but now i have a check engine light on and the throttle responce isnt quite right.
the only problem i ran into was running the tbw connector back thru the bars,the green plug pulled apart an broke the plug so...i came here an searched an found this http://hdforums.com/forum/electrical...-wiring-2.html but the colors on the wires are not right but i put it back as to the page.
can anyone help with the wiring dig. and wire colors form both sides of the plug ?
i have a red purple grey brown blue black off the main harness and and 2 reds 2 blacks an 2 whites off the grip harness.
what goes where?
thank u
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-22-2009, 02:08 AM
genedjr's Avatar
genedjr genedjr is offline
2003 Harley Davidson Road King
Unfortuantely - you need to buy the services manual, parts manual. And maybe the electrical troubleshooting manual.
Its just that complex.
...gene
__________________
2003 Road King Classic
SE Air, Slip-ons, ME880
Andrews EZ Pushrods
Thundermax w/Autotune
Max Power 71.22, Max Torque 80.54 @6000ft elevation (pre-TMax)
Old 10-22-2009, 06:53 AM
timvan's Avatar
timvan timvan is offline
Which code is ti throwing? If you slamemd the tbw unit into the bars, dropped it or had any misfortune...go get a new one. They are very sensitive to side loads and will throw a code instantly.
__________________
2009 107" Vivid Black Ultra Classic, Chromed Comfort with a kick!
2003 Bourget Fat Daddy 117" N20 - Tire Smoker
Old 10-22-2009, 06:59 AM
MassHD's Avatar
MassHD MassHD is offline
Go buy the one piece tbw at the HD store. It's much easier than the two piece. Pm me if you have a problem reconnecting the old plug to the new one piece set up.
__________________
2010 Road Glide Denim Black
ABS Cruise Factory Security
Firecap's Arc amp 125.2, Arc 6 1/2" FD speakers
Old 10-22-2009, 09:14 AM
dawg's Avatar
dawg dawg is offline
You need 32310-08 which is the sensor without the green clip and is used for internally wired bars. The OE is 32305-08 and has the green clip. Once the clip breaks, it is no good. I've posted the wiring color codes for the 32310-08 grip here before.
__________________
'08 105th anniversary Ultra
D&D Fatcat
Zippers Redshift 575 cams
EVO Ind. 30 tooth
SERT
www.vtroaddawgs.com
www.roaddawgs.com
Old 10-22-2009, 02:38 PM
FunkyNova66's Avatar
FunkyNova66 FunkyNova66 is offline
You broke the plug completely? Are you able to access the wires inside the bars? This is why I extended the TBW wires enough to where I didn't have to stuff the plug in the bars. My bars already had enough wires stuff in it as it was. I had to do each wire one by one in order to not mix up the two reds, whites and blacks.
I was told Harley programmed their bikes to go into safe mode (idle only) if something was to go wrong with the TBW (in this case you have crushed the plug and probably crossed wires).
So.... what are you wanting to do?
Are you simply trying to solder the wires together at the plug location inside the bars? or do you plan to replace the plug?
__________________
There are always more sheep than wolves.
Old 10-22-2009, 06:30 PM
kingkingking's Avatar
kingkingking kingkingking is offline
I broke that little green connector too.
I just cut it out and soldered up the wires.
I have the electrical service manual. If you want I can look up the colour codes.
__________________
2009 King - "One King to Rule them All"
Flame Blue / Pewter Pearl. HDI spec - ABS and Security etc. ABS disabled (its rubbish).
S&S 124 hot set up kit w S&S 640 gear driven cams / SE 58mm TB and injectors / SEST / Feuling pump and plate / V&H Power Duals / V&H Basic Slip Ons. 12.25 @108mph with screen n bags on.
Secret Weapon - Escort 9500ci
Old 10-22-2009, 09:20 PM
Hang Around
Quote:
thank u dawg ive searched an think i found it but i still have a engine light an only 1/4 throttle ?
funky,the clip broke while pulling the wires back thru the bars. the stock wiring is long enough but i dont understand..u extended ur wires but didnt put it back thru the bars ?
thats where im getting confused is where the reds, white an black go to which wire on the main harness.
im going to get rid of the plug completly an solder an heat shrink the wires to just hard wire it.
Old 10-22-2009, 09:27 PM
Hang Around
king,
i think i have the correct wires together if u can double check ?
from black wrap;
bk-bk
wh-blu
red-brown
yellow wrap;
bk-grey
wh-viol
red-red
got things back together again tonight and still have a engine light an 1/4 throttle-guess this would be "safe mode" ?
i unpluged the battery for 1 hr to try an reset the comp with no luck.
how can i check for codes ?
is there anyway to check the tbw sensor without taking it to the dealer?
any help would greatly help
thanks again
Old 10-22-2009, 09:33 PM
dawg's Avatar
Blue goes to the white wire from the black sleeve
Black goes to the black wire from the white sleeve
Brown goes to the red wire from the black sleeve
Red goes to the red wire from the yellow sleeve
Purple goes to the white wire from the yellow sleeve
Grey goes to the black wire from the yellow sleeve
__________________
D&D Fatcat
EVO Ind. 30 tooth
SERT
www.vtroaddawgs.com
www.roaddawgs.com
Tags
14, apes, bad, california, custom, glide, harley, roadglide, running, street, tbw, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
