Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-21-2009, 10:26 PM
bamorris2 bamorris2 is offline
2009 Harley-Davidson Road King Classic
Default New Screws Really Needed When Replacing Rotors?
Going to install new HD floating rotors. Both the service manual and instruction sheet caution to use new screws when replacing the rotor.
Why is this? I could understand if these were tigh torque and soft metal, but we're only talking about max 24 ft lbs.
I know the screws are relatively cheap, but still, what's the need? Seems like more of a CYA for HD, plus a way to get yet more money out of us. Yes the rotors come with new screws, but for crying out loud, why couldn't they aT least provide chrome screws with chrome rotors!!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-21-2009, 11:20 PM
stro1965's Avatar
stro1965 stro1965 is offline
I re-use mine and I know many others do too.
__________________
Old 10-22-2009, 01:04 AM
Well I installed them tonight. Re-used the bolts too. There was a lot of dried red LocTite on them, but I used a wire brush to clean them up real well. The threads were all in good shape, so I think they'll be fine.
__________________
2009 Road King Classic
Vivid Black
Old 10-22-2009, 01:50 AM
oinker02 oinker02 is offline
I've seen way too many rear pulley bolts shear off the rear wheel to not use new ones whenever the pulley gets removed and replaced.
I apply that same caution to brake rotors.
You can't see the damage that occurs to a bolt once it has been stretched by torque. We actually stretch bolts when we torque them, where in fact a torque spec itself is an indirect measurement of desired bolt stretch. Some bolts are sized and designed to be torqued and retorqued many times where they are never stretched beyond thier elasticity when torqued to required specs, but sometimes the spec'd torque takes them to their design limits where they are not intended to be reused by design.
You will find this with many modern auto engine head and rod bolts where the MOCO insists you use new bolts each time.
Myself, I play it safe and follow the MOCO's specs.
There are lots of invisible stresses generated on rotor bolts....Brake rotors get toutured by heat and rotating torque...When the rotor gets scalding hot it increases in thickness and places additional stretch on the bolts at their heads, then those hot stretched bolts are subjected to tremendous shear stress as the brakes are applied. A dragging brake often goes unnoticed where the rotor never gets a chance to cool between braking events and it enters those cycles at elevated temps placing even more stress on the head of those rather small screws.
Think about how often you apply especially the front brake and then imagine how many heat/stress cycles described above occur in the life of those bolts and maybe then you will do like suggested and toss the old ones in the trash.
Like you said, they are cheap, they are included and you already have them out......they are one small step from the trash can, huh?
__________________
Bar Hopper
Old 10-22-2009, 02:17 AM
wattspd's Avatar
wattspd wattspd is offline
Prospect
Old 10-22-2009, 07:54 AM
harley-jones harley-jones is offline
Oinker02's post is well thought out and does make sense.
I have re-used the old ones in the past, but I think new bolt are probably the best choice.
One less thing to worry about.
__________________
1999 FatBoy
2008 SG
Old 10-22-2009, 08:13 AM
47Norton's Avatar
47Norton 47Norton is offline
Prospect
Oinker, Very well said. If you need any more incentive to buy new bolts just try to visualize what will happen when these bolts fail at speed while you are braking. It's an ugly picture.
__________________
2000 Road King Classic
"I don't want a pickle, Just want to ride my motorsickle". Robert Zimmerman
Old 10-22-2009, 08:50 AM
leckmc's Avatar
leckmc leckmc is offline
Senior Rider
Agree with Oinker. I'd follow the HD guidelines as there is a lot of stress on the bolts.
__________________
1st HD was 57 panhead (about 1973) -- now ride 2008 Ultra Classic
Old 10-22-2009, 10:29 AM
genedjr's Avatar
genedjr genedjr is offline
2003 Harley Davidson Road King
Default Mr. Willis was right!
Oinker is correct and provided a really good look at the stresses.
But more importantly are the shearing stress applied when you use your brakes. The teeny bolts get used to this stress and how its aligned with the position of the bolt as fastened to the wheel.
When you reuse the bolt there is almost no way to make sure that bolt has exactly the same orientation in the wheel. So you change the sheering force direction. It's exactly like bending a nail back and forth - it will break eventually.
I was taught this eons ago in a high school metalshop class.
Thank you Mr. Willis.
...gene
__________________
2003 Road King Classic
SE Air, Slip-ons, ME880
Andrews EZ Pushrods
Thundermax w/Autotune
Max Power 71.22, Max Torque 80.54 @6000ft elevation (pre-TMax)
Old 10-22-2009, 10:46 AM
Our07Ultra's Avatar
Our07Ultra Our07Ultra is offline
Hey Oinker..Thanks for the informative post! Very well stated. This is what this site is all about!
__________________
2007 Ultra Classic White Gold Pearl
Rinehart True Duals,SERT,SE A/C
Life is tough, it's even tougher if you are stupid...John Wayne
Tags
bolts, brake, buy, change, changing, front, harley, installing, motorcycle, needed, rotor, rotors, screws, sportster, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
