Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-21-2009, 09:36 PM
FFeric FFeric is offline
Default Single sided brake a bad idea?
I can't believe I am thinking it, but I been toying with the idea of a 21in front wheel. But I thought if I am going to do it, why not make it single sided.
My bike is an 06 SG. I am not a big guy. Under 170. Would a single sided brake be unsafe? What about going with a 6 piston brake? Thoughts?
Thanks
Eric
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-21-2009, 09:45 PM
qtrracer qtrracer is online now
Senior Rider
Well you are reducing the contact patch on the front tire so you will have less traction anyways so if you have less braking power up front it might not be a bad thing. Had a Fatboy they only had a single sided disc up front , but they don't weigh as much and are not rated to carry as much as the SG. I think HD uses duals up front to reduce brake fade due to excessive heat when loaded down. I would go 13" if I had to go single sided up front.
__________________
08 SG 103" SE MVA Heads 251 Cams SE 58mm TB RB LSR 2-1
Old 10-21-2009, 09:52 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00 bigdumbnoitall00 is offline
should be ok as long as u use good quality stuff,and u ride it acordingly. but still wont be as good.
__________________
springs almost here we can already see the deer!
Old 10-21-2009, 09:53 PM
kingkingking's Avatar
kingkingking kingkingking is offline
Depends how you ride and the terrain you ride in. If you find yourself braking from 95 into a 25mph corner down a 1 : 15 grade often then 2 discs on a 800+lb bike are a good idea. If the hardest braking you do is a light squeeze in the pub parking lot then you will be fine.
__________________
2009 King - "One King to Rule them All"
Flame Blue / Pewter Pearl. HDI spec - ABS and Security etc. ABS disabled (its rubbish).
S&S 124 hot set up kit w S&S 640 gear driven cams / SE 58mm TB and injectors / SEST / Feuling pump and plate / V&H Power Duals / V&H Basic Slip Ons. 12.25 @108mph with screen n bags on.
Secret Weapon - Escort 9500ci
Old 10-21-2009, 09:54 PM
just remembered seeing a single set up in here that was simialar to the buel set up with the rotor mounted on the outside dia of the wheel looked pretty slick.
__________________
Old 10-21-2009, 10:00 PM
YtseJam's Avatar
YtseJam YtseJam is online now
Senior Rider
2001 HD FLHT
My Garage
Not being a big fan of HD brakes, don't see how much worse it can get. I had also played with the idea of a 360 Brake...still may do it. If you do decide, let us know how it works out for you.....
__________________
http://www.hdforums.com/forum/image.php?u=22476&type=sigpic&dateline=1228586078
2001 EG....Standard?
2006 Hayabusa
Old 10-21-2009, 10:07 PM
I am not an aggressive rider. So with a good brake like Performance Machine and a larger disk would be good? Or do you think it is just a bad idea?
Old 10-21-2009, 10:09 PM
Is the 360 brake pretty new? Dependable?
Old 10-21-2009, 10:10 PM
Quote:
Nah go for it. The calipers on your 06 were nothing to write home about. if you go for a decent 4 or 6 piston PM or similar you might actually end up better off!!
__________________
Old 10-21-2009, 10:29 PM
It never ends does it? I was thinking about a new set of wheels, maybe contrast cut. But that would be expensive. So I was thinking the same style wheel just in a 21inch.
Tags
brakes, harley, sided, single, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
