Due to some noise that I'm hearing in my primary, I want to check the "compensator nut" that I've read about so many times on the forums. But in looking at the service manual, I don't see a "compensator nut" at all. What I DO see is a "compensating bolt". It looks like it's what holds a sprocket on the flywheel. Is that what everyone is referring to? I ask because it is obviously not a "nut" at all, but rather a bolt.
Also, when you tighten it, how do you lock the sprockets in place so they won't move. I see that HD has a special tool for it, but what about a homemade solution?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
2009 Road King Classic
Vivid Black
it is a nut. bolts are male nuts are female and the comp nut might look like a bolt to some but is really a nut LOL. it is seasy to make your own tool with a piece of 1" flat stock.
Actually, you can make the locking tool out of a piece of 2X4 wood.
The compensator nut is just that. It's about 2 1/2" long and is threaded on the inside.
When ya use the tool to lock the sproket, be you DO NOT have it wedged UNDER the sprocket. You can damage your chain tensioner pad. When tightening the nut, read the manual real close about the proper torque and then the additional turn.
When the nut is properly tightened, check it real close to be sure it is seated properly and does not touch the inside of the outer primary cover.
__________________
Ken
2006 Silver Road Glide
103 Stroker/SE258 cam, pistons, heads & other stuff
Marine Corps 1968 - 1993 GySgt (Ret)
JFFJ
Heart aching for Wendy
Ok, but again, I don't see a NUT anywhere in the illustrations.
What I see is a BOLT, as illustrated in post #3 (item #6 on the illustration). This is very different from what everyone always says about tightening the compensator NUT.
__________________
Vivid Black
earlier models used a large Nut about 1 and 1/2 inches in diameter ...........the late model compensators such as yours have been redisgned an uses a BOLT to hold the compensator on.....the photo in the manual is correct....be sure and follow all of the tightening procedures to insure a proper torque.
__________________
2009 FLHX / Fast Black
Chrome Acorn Nut on Mirror
AF&AM
Cool, thanks twincam47! A quick question, if you know... Is it common for the redesigned compensators to come loose too? Or are most of the reports of "loose compensator nuts" from the previous versions?
__________________
Vivid Black
Does anyone know?
__________________
Vivid Black
if you have done any upgrade to your engine, ie 103ci or se255 cams, you will find that the stock compensator may no longer be stout enough for your engine. I ran into this on my '07 Ultra after the above mentioned upgrade. Had the stock compensator replaced, did no good. Mine was causing serious starting issues like the starter was stripping out the gears. It was not. Solution was an SE compensator install. cured all my problems. It consist of about a dozen pieces rather than about 5 with the stock compensator and does a much better job of keeping the slack out of the primary chain at all times, especially during start up. You might consider the SE compensator upgrade, will probably cure any ailments you seem to have.
