Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-19-2009, 01:42 PM
mccollde's Avatar
mccollde mccollde is offline
Prospect
Default Power Commander or Race Tuner???
Can someone explain to me in dummy terms the difference in a race tuner and a power commander type system? I know the Power Commander type tuner stays mounted on the bike but I dont understand the differences. I know there is lots of info on here about this topic but most of it is greek to me. Until now everything i've had has been stock. Also your opinion on which is the best way to go will be appreciated.
If it makes a difference i have the SE Ventilator Air Cleaner. Rinehart Mufflers....not sure on the exhaust but it will either be V&H Dresser Duals or the Jackpot 2-1-2.
Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-19-2009, 01:57 PM
Leftcoaster's Avatar
Leftcoaster Leftcoaster is offline
I'll take a shot at it:
SERT is made by HD and is a computer link that allows one to access the ECM (brain of your bike) with a computer.
The Power Commander is a piggy-back unit that modifies the ECM in much the same manner except it stays on the bike. Either unit is only as good as the person programming it and there are arguably many more capable PC techs than there are for SERT.
__________________
Just smart enough to know how stupid I am.
Old 10-19-2009, 02:06 PM
abate1 abate1 is offline
Prospect
SERT is like downloading a program into your computer, PC is like plugging in a seperate item to your computer via a USB port. Both adjust your fuel, timing but like said in leftcoasters post both are only as good as the tuner. My vote goes for PC, if anything everygoes wrong you can unplug and get home JMHO
__________________
Doc
1980 FLT TOURGLIDE
2007 ELECTRA GLIDE CLASSIC
Old 10-19-2009, 02:09 PM
brettnbama's Avatar
brettnbama brettnbama is offline
These other guys are on it, plus IMO one of the biggest things is if you make changes to the bike later on, good tuners like Jamie at Fuelmoto will send you updated maps at no charge. If I am not mistaken, even with the SERT, you will have to go back to HD and have them do it, I bet they will charge you.....
__________________
09 Vivid Black Road King
09 HD Iron 1200
Old 10-19-2009, 02:10 PM
qtrracer qtrracer is offline
Senior Rider
Don't know what year your bike is but most of the Power Commanders remove the O2 sensors on those bikes equipped with them so they are not able to "read " how your bike is running. The new Power Commander with autotune uses O2 sensors but i do not know if you can use your existing O2 sensors if you bike is equipped with them or if you have to buy new ones from them.
__________________
08 SG 103" SE MVA Heads 251 Cams SE 58mm TB RB LSR 2-1
Old 10-19-2009, 03:22 PM
cmashark's Avatar
cmashark cmashark is offline
Prospect
Hold up, now.... The sert can turn off the 02 sensors. Once they are off, they can be removed. If you have a good dyno tuner in your area or are willing to buy a Twin Scan II+ and make your own maps, the sert would be the best option. For people like me without any good tuners (also don't think the Twin Scan would work with the new Super Tuner) the best option is a piggy back device.
Chris
__________________
2009 FLHT-V&H Power Duals, Jackpots, PCV, VO2 Drak A/C, 255's, Agitators, biketronics stereo.....ect
http://i249.photobucket.com/albums/g...2008/glide.jpg
Old 10-19-2009, 03:31 PM
Senior Rider
There is a difference between can remove and have to remove, that's what I was pointing out. I was not knocking the Dynojet Power Commander at all.
__________________
Old 10-19-2009, 03:45 PM
07JakeelwoodHD's Avatar
07JakeelwoodHD 07JakeelwoodHD is offline
Senior Rider
I have used Rivco race fueler,SERT,F-M PCV ..BY far the best is PCV then R/F then SERT...
__________________
09 HD Ultra Candy Rootbeer
FM PCV Rhineharts S/O S/E AC KN filter
07 HD Ultra Jake Elwood blue sold
Rinehart Slipons SERT S/E AC
02 HD FLHTCUI SE Exhaust SE AC race fueler
Old 10-19-2009, 03:55 PM
Heatwave Heatwave is offline
Prospect
Thanks.
FYI, just for accuracy, there is no longer any tuning software referred to as SERT or Race Tuner. Harley now refers to their tuner as the Pro SuperTuner. The SERT or RaceTuner is their older product.
I have both. The SERT on my FI 2003 Fatboy and the SuperTuner on my 2010 SE Ultra.
Until very recently, I would have suggested staying away from the Pro SuperTuner. However if you have interest in tweaking your bike yourself either after a dyno tune (due to an exhaust change for example) or without ever doing a dyno tune, the SuperTuner has some very neat capabilities that I am only begining to explore on my 2010 SE Ultra.
The Pro ST has a VCI or ECU recorder that you can activate, store in a saddlebag (it's the size of a cigarette pack) and use to store the performance of your bike. After saving a few rides, you can then download the engine performance file back to your laptop. Once the file is back on the laptop you can run SmartTune to generate recommended changes to your existing ECU MAP. You can then save the updated map with the SmartTune changes back to your bike and check out the improvements from the saddle.
The improvements on my bike were actually quite good and I'm now beginning to like the SuperTuner as I learn more about it.
__________________
2010 FLHTCUSE5 (SE Ultra) Scarlet Red Pearl/Dark Slate with Flames
http://hdforums.com/forum/image.php?type=sigpic&userid=98179&dateline=125094  3547
Old 10-19-2009, 04:03 PM
Indianspringsaz Indianspringsaz is offline
The SERT or the TTS are far more tunable than the PC. I didnt say easier.
__________________
07 Road King Standard,
107 GMR
Andrews 54
D&D Fat Cat
Ness Big Sucker
SERT 107/115
Neighborhood Amsoil Dealer
Tags
commander, davidson, electra, evo, forum, glide, greek, harley, maps, pc3, power, purchaseharley, race, tuner, usb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
