The PC-V uses the ECM's J1850 data bus for its channels including engine temp. The PC-V does not feature an output for these channels. When available you can use the Dynojet LCD display which will read all channels and engine parameters in real time and if you have the Auto tune it will read real time AFR as well.
Went straight to the dealer to get the matching gauge for my bike, works great but in the beginning I wished I hadn't done it. You get to watching it when you first install it but after a while the newness goes away then it's all good.
__________________
08 SG 103" SE MVA Heads 251 Cams SE 58mm TB RB LSR 2-1
