Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-10-2009, 02:04 PM
patriotmc's Avatar
patriotmc patriotmc is online now
Prospect
Default Need help: new cams or 103 upgrade
I've been thinking of goiing with the 103 KIT. The dealer has it on sale this winter for $1650 installed. After reading these posts, it looks like I'll also have to install the compression releases... so more money.
As an alternative, I'm thinking I could just put new cams in and forgo the 103 upgrade. I'm not unhappy with the performance I have now... I do a lot of 2-up riding, so a little extra torque and hp would be nice. Don't know if I'd get that much or not... can you help? Also, what kind of cams would you suggest to give me good power up to 4500 rpm.
My ride: 07 Ultra, SERT, SE A/C, SE II slipons.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
A MN Patriot Guard Rider - because I care!
07 Patriot Edition Ultra Classic – US Marine Corps
SE 255 cams, SE A/C, SE II Slip-ons, SERT - 82HP/97TQ
Old 10-10-2009, 02:27 PM
iclick's Avatar
iclick iclick is offline
There are quite a few discussions about cams here recently, so do a search and you'll find lots of ideas. I was also happy with the performance of my '07 with the Fuel Moto Power Package, but decided to go with SE255 cams after finding a used but perfect pair for $110 from a forum member and deciding I could do the work myself. After spending a total of $285 and a day of work I had the upgrade I was looking for, which was more low-end and midrange torque without making any other engine mods. With some creative cost-cutting you could probably get the cost down to about $200.
These cams don't produce great peak-HP numbers and are designed for torque, which they do very well with a stock engine. The sweet spot is about 2300-4500rpm on my bike, which is exactly where I ride, and the extreme low-end (below 2500) is not decreased like it would be with most other cams on the market given stock compression. You can read my write-up here.
A Stage II (103, flat-tops, and 255's) will give you more displacement and higher compression, which will enhance performance even more. I've seen some very impressive dyno charts with this kit if torque is your game.
What I think is a good idea is to try the 255's alone first, then if you want more add the 103 kit and flat-top pistons.
__________________
2007 Street Ultra
Stage 1½: Fuel Moto Power Package, SE255 cams.
http://www.iclickphotos.com/Motorcycle/0000-080702-04aLH-Bike.jpg
Link to larger image
Old 10-10-2009, 04:36 PM
FLHX 2009's Avatar
FLHX 2009 FLHX 2009 is offline
Hang Around
Im looking at going with the new 259E's with a 103 build.
Old 10-10-2009, 05:47 PM
EG Ultra Classic EG Ultra Classic is offline
Senior Rider
Send a message via Yahoo to EG Ultra Classic
I'd recommend doing the entire SEII 103 bore kit with cams, tuner, a/c pipes and dyno tune.
Just cams ???? naaaah, forget that.
__________________
2008 Ultra Classic FLHTCU Stage II 103 HD kit- SE 255 cams, SERT, stock 96" heads, manual compression releases, SE high torque starter, Capt. Itch crotch cooler, and BUB 7 exhaust. 86 HP, 103 TQ
2008 Triumph Rocket 3-Touring, 2300 cc triple cyl. WOW!
Old 10-10-2009, 06:11 PM
BennieSG's Avatar
BennieSG BennieSG is offline
Prospect
Quote:
Kit alone cost $800 and another $850 to install? That seems pretty high especially for a sale price. Should not be more than $500 to install.
__________________
09 FLHX stage II 103 kit with rineharts and tuner....and more to come!!
Old 10-10-2009, 06:45 PM
patriotmc's Avatar
Prospect
Would you need the compression release if you only but the SE 255's in?
__________________
Old 10-10-2009, 06:51 PM
Spartacus55 Spartacus55 is offline
Hang Around
i have the se 103 kit with the 255 cams and they kept the compression under 10 to 1 no compression releases needed for my 2007 rk dyno'd at 85 hp and 104 tq with rinehart truduals and se hi flo air filter plenty of get up and go.
Old 10-10-2009, 08:23 PM
jag1886's Avatar
jag1886 jag1886 is offline
2007 Harley Road king
My Garage
I did a cam upgrade last winter I used a Head Quarters HQ500 cam in my bike and I am very pleased with the results. The bike runs WAY better than it did, it sounds WAY better than it did, it has no starting problems like so many 103's have, in doesn't bang anymore on start ups like before, and I think 90 HP and 93 lbs of torq are pretty impressive for a 96" engine with just a cam, a set of FatCats, air cleaner and a good tune with a SERT.
My bike hauls ass, this winter I'm going to do the 49T ring gear that Evolution sells and I think I'm going to be happy with this combo for quite a while.
I don't think the Harley 103" kit is that impressive for what it costs, it only gets a little more torque than my set up and usually less HP.
__________________
JAG1886
2007 Road King
2000 1200 Sportster
2003 1200 Sportster
Old 10-10-2009, 08:26 PM
UltraKla$$ic's Avatar
UltraKla$$ic UltraKla$$ic is offline
Talking
I built a 103 w/SE255 and I dang sure needed compression releases. I'd be buying a starter if I had not put them in. I bumped my Static Compression to 10.01:1 and Cold Cranking Compression to 204 though.
HERE is a thread of my build. Different ways to go about getting there, but I LOVE my build. Push in the releases, hit the starter and you hear......psssst....psssst.....VROooomm.
If you do just cams then you should not need CR's. If you choose to do the whole enchilada, put the releases just to be safe. It doesn't take but an extra 20-30minutes for them to drill them out.
__________________
http://www.hdforums.com/forum/image.php?type=sigpic&userid=22122&dateline=121958  7778
2007 UltraClassic\103"BB\.030 Cometic Head Gasket\SE 255's
Doherty PowerPACC w/vents\Supertrapp SE's\SERT\Bagger Brace
M1 15W-50 in crank\Redline MTL in Primary\Redline Shockproof in Tranny
My other toy!
Old 10-11-2009, 09:29 AM
WVULTRA's Avatar
WVULTRA WVULTRA is offline
jag1886:
Agree your numbers are very good! But not all H-D StageII 103" assemblies are created equal:
__________________
'07 Ultra Classic
Crane HTC 300-2 @ +4*
SE Breather w/Zippers Max-Flow
Kury Tru Duals
'09 CVO/Fullsac Slip-Ons
TTS Mastertune
Front Brembo Brake Conversion
Tags
103, 255, cam, cams, camshaft, camshafts, eagle, engine, harley, hd, hq0034, sale, screaming, upgrade, upgraded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
