Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-05-2009, 07:41 PM
XTrooper3936's Avatar
XTrooper3936 XTrooper3936 is offline
Default Technical Service Bulletin M-1252
If someone could make available to me a copy of TSB M-1252 regarding the replacement of cracked/leaking transmission cases, I'd be deeply appreciative. My 2008 FLHT developed an oil leak recently and when I pulled the starter today, I found a pool of oil on top of the transmission. The oil appears to be coming from the area of the speed sensor which is threaded into the top of the transmission case. Before I contact the dealer, I'd like to be armed with a copy of the TSB.
Thanks!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Steve
NJSP - Retired 4/91 Life Member: VFW, VVA
2008 FLHT "Electra Glide In Blue"
ABS, cruise, chrome engine kit, Biketronics stereo, SE 103 ci kit, SE 1.725 rocker arms, SE intake, SE touring mufflers
Old 10-05-2009, 10:19 PM
08KING's Avatar
08KING 08KING is offline
I am curious also, here is a bump
__________________
08 ROAD KING (FLHR)
SE A/C
PCIII
V&H OVALS
Old 10-07-2009, 11:54 PM
wglide69 wglide69 is offline
Hang Around
I have an 08 FLHRC and have the same problem. It started months ago and have had the bike to the dealer three times. Oil pools on top of tranny, then runs down and is thrown back by the drive gear. First time in they thought it was an inner primary problem, second time in they thought the vehicle speed sensor o ring was leaking (this made some sense) but I got it back and it still leaked. Getting pissed by now. The third time it went in, they said they found a cut o ring I believe where the starter mounts to the inner primary. Had them replace the starter also cause of the 08 starter paint flaking problem.
I had asked them about this bulletin and they dismissed a bad casing as the problem. I have only put about 70 miles on since I got it back, but no leaks in 70 miles. My luck with this problem.....I may have a bad casing who knows hope not.
You may have a different problem, just thought I would pass this along. Also, if you take it in, I would have them put on a new starter......many have had paint problems. Mine flaked a bit when they reinstalled after checking out the vehicle speed sensor.
Old 10-07-2009, 11:59 PM
tda69 tda69 is offline
So far I haven't had any issues on my bike, but I'll keep an eye out for anythign that develops. This is one of the many reasons why I enjoy this forum so much.
__________________
http://i114.photobucket.com/albums/n280/03fhtcui/08Ultra.jpg
'08 Ultra Classic with ABS
http://www.myspace.com/thewildhogs
Old 10-08-2009, 05:52 AM
Thanks for relating your experiences.
In my situation, I've pulled the starter more times than I care to remember (I think I could do it blindfolded now) and I'm now almost 100% sure that the leaking is not coming from the starter though the Tech Cycle hi-torque starter I installed after the 103 cid upgrade was intially my prime suspect. I've since replaced the Tech Cycle starter with a H-D hi-torque and a new starter o-ring, so I'm pretty sure that source has been eliminated. Both the Tech Cycle and new Harley starters are both chrome-plated, so flaking paint wasn't an issue I had to deal with.
__________________
Steve
Old 10-08-2009, 05:55 AM
Can't anyone provide a copy of service bulletin M-1252?
I'd really like to have a copy in hand when I speak to the service manager. Thanks!
__________________
Steve
Old 10-08-2009, 08:34 AM
smokindave's Avatar
smokindave smokindave is offline
Senior Rider
Take a look at the rear drive seal coming out of the tranny, just had mine replaced. It is a small o-ring that can be replaced without taking out the tranny. Remove the primary and you can then use a pick to take out the old o-ring but, there is a tool for installing the new one. Got a service manual, it's in there. If this is your leak, think about putting on a SE compensator sprocket at the same time, you will be glad you did.
__________________
Some things you just have to learn yourself....
08' SG
Old 10-08-2009, 09:04 AM
petemac's Avatar
petemac petemac is offline
Steve, pm dawg and he should be able to help you out.
__________________
2006 Road King Classic
Vivid Black
95" with heads ported by Big Boyz
V&H True Duals and Ovals
SE hydraulic tensioner upgrade
Andrews 26 cams
SERT
Old 10-08-2009, 10:09 AM
twincam47 twincam47 is offline
Senior Rider
m1252 has nothing to do with a cracked case. It is a bulletin advising the dealers that they should order tranny components instead of the complete assembly from now on. Replace the affected parts instead of just replacing the entire tranny.
__________________
2009 FLHX / Fast Black
Chrome Acorn Nut on Mirror
AF&AM
Tags
2008, bulletin, bulletins, classic, compensator, davidson, electra, flht, glide, harley, ignition, king, road, sensor, service, technical
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
