Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-04-2009, 05:04 PM
MoonMan MoonMan is offline
Hang Around
Default What is the best cam for my FLHTC?
I own a ’07 FLHTCU that was upgraded to the stage II 103 ci (80hp & 103tq with 255 cams, Rinehart true-duals w/quiet baffles, & SERT) not long after I bought it. I've been told by several people I should have better hp & tq numbers with this build. Also, I’ve gone through a couple of starters since then and need to do something different now that my warranty has expired. I have a buddy with a similar build that added push-button compression releases after his second starter replacement and his starts great now. I know the biggest changes I’ve noticed on other bikes I’ve owned have always come from head/cam work, but I really can't afford to get too radical right now.
When I wind this bike up I’m at 100 mph when I hit 4th gear and right at 120 mph when I shift into 5th at 6200 rpm. Getting to 100 mph doesn’t take long (3rd gear is awesome), but the pull from 4th to 5th takes a little while. I’m getting older, plus both the bikes and I are getting heavier, so I don’t do this every day; but I do have a long, secluded stretch of road near my home where I like to go for an occasional adrenalin rush. The rest of my time on the bike is spent with year round highway cruising between 65-85 mph (with occasional bursts) on 50 mile round-trips to work and 1000 mile round-trips to visit family.
I'm currently looking at the S&S 551 or 583 Easy Start Cams. I can do that pretty cheap and don't even have to pull the heads. One of my buddies, that seems to know a great deal than I do about lift and duration, told me that I should go with the 583, but I'm wondering if there will be too much of a difference on the low-end during take off. You have to feather the clutch and throttle to get all of that weight going now. He also told me that I could get a regular cam with better duration and valve timing and the starting wouldn't be an issue at my current 10:1 compression ratio. What I'm asking if there is anyone out there that could tell me about these two cams or recommend another grind that will work well with my setup. I wouldn't mind a little more power and definetly got to start better.
Thanks for any suggestions!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-15-2009, 09:35 AM
chasswartz's Avatar
chasswartz chasswartz is offline
Hang Around
I am also looking at those 2 cams. I like the HP/TQ curve of the 583 best, but am concerned about the .583 lift with stock springs and clearance. I know this doesn't help but maybe some cam expert can chime in.
Old 10-15-2009, 10:13 AM
THABULL THABULL is offline
I have a stock 07 96 with SE255 cams , KN a/f , PCIII and D&D Fat-Cat and I have 83HP and 98FT.LBS. I give my exhaust alot of credit for my #'s!
__________________
<a href=http://i220.photobucket.com/albums/dd215/thabull8471/100_0365.jpg target=_blank>http://i220.photobucket.com/albums/d...1/100_0365.jpg</a>
Old 10-15-2009, 10:28 AM
dirtdobber's Avatar
dirtdobber dirtdobber is offline
Do you mind tell us why you have to feather the clutch.
I have the SE 255 cams only-still 96 ci. Pulls like a tractor . About 115 is about all I can get out of it. 100 is easy and quick.
From the sounds of it you have all the speed you need.
I would be surprised if you find a different cam that pulls as good as the SE 255 in the lower rpm range.
Are you experiencing problems on take off?
I had a problem for a while. Had to feather the clutch because of a jerking, like it was geared way to high, it is some. When loaded and 2 up was when it was it's worse. Turned out to be the compensator sprocket. Not saying it's the same thing you are referring to. I went to the SE compensator and solved my problem.
just a thought
in God we Trust
dd
__________________
http://bigbikeriders.com/photopost/data/500/medium/7988IMG_1875_edited-1_Small_.jpg
Old 10-15-2009, 06:43 PM
mastery's Avatar
mastery mastery is offline
Quote:
What's the SE compensator cost?
__________________
Old 10-15-2009, 06:55 PM
Barrenmug's Avatar
Barrenmug Barrenmug is offline
Quote:
SE list for $249.95 from their catalog
__________________
"Only the mediocre are always at their best."
"We learn from history that we learn nothing from history."
2007 FLHTCU Vivid Black
V&H True Duals/ Rush 2"
PCIII & K&N Filter
Tags
103, 551, 583, biggest, cam, cams, ci, davidson, easy, easystart, harley, harleys, ss, start, touring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
