Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Touring Models
Sponsored by: Fuel Moto USA
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
  #31
Old 10-01-2009, 12:22 PM
myred55's Avatar
myred55 myred55 is offline
Senior Rider
1955 Chevrolet 210 post
Quote:
Originally Posted by SafetyMan View Post
I put mine on my Softail, but there's no reason you couldn't adapt the process to your bike.
I wanted to install a garage door opener on my scoot, without giving the MoCo $130 bucks, so I used an existing visor mount model, and installed it in the dash. From the outside, there is no way to tell it's there.
Not counting the connectors and wire, which I already had, and the opener, which I already had, I have a total of 9 bucks, and 2 hours in this project.
This is a really simple project, if you trust yourself with a test light, a continuity tester and a soldering iron.
Here's how to do it:
First, make sure you have a 12 volt unit. The battery will tell you how many volts. A 12v battery is near the diameter of a AA, but it is shorter.
__________________________________________________ __________________________________________
Second is the parts I needed.
HD# 67880-94 is the rubber boot.
HD# 67854-98 is the Speedometer Reset switch.
The opener, some wire, I used red for hot, black for ground, and purple for the switch.
A 3M Quick Connect, for the hot lead.
Shrink tube and heat-shrink connectors, I like waterproof.
And most important, if you follow the green arrow... Diet Coke.
This is what it looks like, when you take it apart.
This is the bottom of your circuit board. The red arrows point to the back of the switch. Note there are 2 poles to each side of the switch.
This is the top of your circuit board. The purple arrow points to the switch, and the red arrows point to 2 of the poles.
Here it is with all of the wires soldered in place. Note where the red arrow is I bent the corner of the switch up. I used a continuity tester to be sure I did not cross the switch, and found I had, so I bent it up a bit.
Be sure you know which pole is hot and which is ground for your power.
Here it is finished, and reassembled.
In the dash...
Yellow arrow: Hot lead to the accessory lead under the ignition switch.
Green arrow: Ground run to the bolt at the top of my engine guard.
Red arrow: New switch installed.
Purple arrow: I wrapped some weatherproof foam and tape around the unit.
Orange arrow: Chickie's Butt.
Here is the new switch installed...
And here it is once again, finished
Green arrow: Speedometer/Clock/Odometer reset
Red arrow: Garage Door Opener
Thank you very much for the detailed proceedure. I have one question, can I use Diet Pepsi instead of Diet Coke?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
"It is easier to ask for forgiveness than permission"
2009 Ultra Classic, Red Hot Sunglow
Jackpot exhaust, Dynojet PC V
Lots of miss. chrome add-ons
HogTunes
Red '55 Chevy (myred55)
Tags
ca, door, garage, harley, inexpensive, king, merced, mount, odometer, opener, openers, relay, reloading, reset, road, spring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
