Did the same thing here, I used a 12v extra remote I had and attached to an odometer reset button. Installed the button on the right side just across from the other button. Remote is resting up inside the batwing. Cost about $10 bucks for the button and rubber cover from HD
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
2008 UC Eglide Stage 1, Detach Tour Pak, Hogtunes 3 Way, V&H True Duals w/ Monster Ovals and Power Commander
I was going to use the acces switch, but didn't like how it was eathier on or off. You can order (for around $20) a Screamin Eagle ultra tourpack lock switch (it's a momentary switch) and put it in one of the blanks. Two wires into it and then soldered to the back of your remote as shown on another post. Saves you from having to drill anything and it looks perfectly factory. Did it on my 08 and now on my 09 SG
__________________
2009 Street Glide
I came home and said "Honey, I won the Lottery, Pack Your Bags!!", she asked "With Summer or Winter Clothes?", I said "I Don't Care, Just Get Out!!"
There are 2 torx screws that are a bit tough to get at. Go under the dash and they are at the top and bottom (front and back) of the blank. If you remove one screw on the side of the dash, you can manouver a bit better. Easier than trying to remove your ignition switch and the whole dash.
__________________
2009 Street Glide
I had one just like that in the beginning, but the darn thing wouldn't work every time and sometimes had to honk 5 or 6 times. I went ahead and switched to the one I have now and it works on the first try everytime.
__________________
The size of a matchbox, no cutting or drilling, you can buy it on Ebay for around $20, it's a REMOCON programmable remote. It works with all garage door openers except rolling code types. Best of all, you can take it with you anywhere you go since it's not attached to your bike! Oh yeah, it can operate motorcycle and car alarms also.
__________________ 2001 FLHRI 95" - SE Hi-Perf. Heads
Henderson Porting - SE Forged Pistons
S&S 570G Cams - BC Gerolomy Modified Throttle Body
SuperTrapp SuperMegs 2-into-1 - PCIII-usb
__________________ "It is easier to ask for forgiveness than permission"
2009 Ultra Classic, Red Hot Sunglow
Jackpot exhaust, Dynojet PC V
Lots of miss. chrome add-ons
HogTunes
Red '55 Chevy (myred55)
